WTB D-Jet Fuel Pump Connector Plug w/pigtail |
pilothyer |
May 24 2010, 01:30 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
The electrical plug going to the fuel pump on my 73 has been cut off by PO when carbs were added.....I need the plug with as much wiring as possible to put back the original D-jet 3 port pump..........Thanks for looking.....Jerry
914Sixer |
May 24 2010, 06:10 AM
Jerry,
Let me look this afternoon. I have several plugs but I am not sure if I have one with a pigtail. |
Jakeodoule |
May 24 2010, 07:02 AM
Member Group: Members Posts: 353 Joined: 10-October 08 From: Des Moines Iowa Member No.: 9,630 Region Association: Pacific Northwest |
The electrical plug going to the fuel pump on my 73 has been cut off by PO when carbs were added.....I need the plug with as much wiring as possible to put back the original D-jet 3 port pump..........Thanks for looking.....Jerry Jerry, I got it. you can have it for cost of shipping. should be able to get as much length as you want. this is the one in the front trunk right? |
bdstone914 |
May 24 2010, 07:04 AM
Jerry,
I have one that is correct for the 73 three port pump. You can have it with the other parts you are buying. I can mail it sooner it you need it. Bruce |
pilothyer |
May 24 2010, 01:19 PM
Jerry, I have one that is correct for the 73 three port pump. You can have it with the other parts you are buying. I can mail it sooner it you need it. Bruce Bruce...Thanks very much....You can just send it with the other parts. I appreciate it very much..........Jerry |
pilothyer |
May 24 2010, 01:32 PM
The electrical plug going to the fuel pump on my 73 has been cut off by PO when carbs were added.....I need the plug with as much wiring as possible to put back the original D-jet 3 port pump..........Thanks for looking.....Jerry Jerry, I got it. you can have it for cost of shipping. should be able to get as much length as you want. this is the one in the front trunk right? Thank you for your offer, but it is the rear mounted fuel pump with three ports. I am not sure the 70-74 rear mounted pump and the 75-76 front mounted pump share the same style connector?...Thanks again though....Jerry |
914Sixer |
May 24 2010, 02:35 PM
No pigtails but I have 3 plugs.
pilothyer |
May 24 2010, 03:38 PM
Lo-Fi Version | Time is now: 16th May 2024 - 03:49 PM |
