| d914 |
May 26 2010, 06:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,350 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
Im looking to pop the doors off,, Two pins in the hinges,,,,,,,hit them with a big hammer and punch or unbolt them...
also the door stay at pillar....?? |
| Spoke |
May 26 2010, 06:44 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,353 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Take the 3 bolts off the top hinge and bottom hinge. Remove the stay pin first.
I usually get a milk crate to rest the door on when loosening the bolts. |
| d914 |
May 26 2010, 06:55 PM
thanks
| pnewman |
May 28 2010, 08:17 PM
Member ![]() ![]() Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
I don't recommend trying to remove the hinge pins. only the door stop / keeper stay pin. You may damage the door sheet metal trying to remove the lower hinge pin. the bolts work fine as he said. Take a pencil and mark the corners of the hinges both on the top and on the bottom hinge to aid in alignment upon re-installation.
Good luck. ...also a second set of hands as well as the milk crate (preferably a plastic one or a metal one with a towel) to pad the top of the crate will help lower the chances of damaging the door during the process. |
| computers4kids |
May 28 2010, 08:31 PM
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
If your door gaps are good, drill a small hole throught the hinge...it works great for quickly re-aligning the door when re-installing.
| jaxdream |
May 29 2010, 08:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Personally , if I were taking them off and remounting them , I would put masking tape around the hinges and on the body , mark the tape with pen , pencil , sharpie ETC , at a few spots around the hinges on the tape so as to have a few reference points to realign to . My $.02.....
Jack / Jaxdream |
| rsrguy3 |
May 29 2010, 08:21 AM
Member ![]() ![]() Group: Members Posts: 136 Joined: 4-April 09 From: Utah Member No.: 10,234 Region Association: None |
What about the pin puller/slide hammer? That seems the slickest way... no door re alignment required.
| J P Stein |
May 29 2010, 09:08 AM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Those hinge pins are right up there with an rear axle nut that hasn't been removed in 40 years. Realigning the door is a piece of cake and the alignment hole idea would make it even easier.
| jaxdream |
May 29 2010, 10:51 AM
Is there room to get a drill with what ever size drill bit in there to drill an alignment hole , like some do for trunk hinges ??
Jack / Jaxdream |
Lo-Fi Version | Time is now: 14th March 2026 - 12:52 AM |
