4 lug fuch in wider width, what width should eagle offer besides 5.5 ? |
jimkelly |
May 26 2010, 06:37 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my guess is 6.5 might be popular for the narrow body crowd which is shrinking every.
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=53 jim |
Chris Pincetich |
May 26 2010, 08:50 PM
7 inch wide
Yes, it fits (IMG:style_emoticons/default/beerchug.gif) BUT that eagle rim would likely be 20lbs each when wider! (IMG:style_emoticons/default/dry.gif) |
May 26 2010, 09:05 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would buy if it was offered in 8 inch width.
Deep lip with the proper offset. Rich |
al weidman |
May 26 2010, 10:26 PM
Al Weidman Group: Members Posts: 156 Joined: 22-February 08 From: Oroville, Ca. Member No.: 8,736 Region Association: Northern California |
I think we've got you covered Rich, AL. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
al weidman |
May 26 2010, 10:36 PM
my guess is 6.5 might be popular for the narrow body crowd which is shrinking every. http://www.aewheel.com/eagle_alloy_wheels.cfm?id=53 jim Jim, 6 1/2 will be easy, we've done 7's with the inch on the inside but I don't think an extra inch on the outside would clear or at the least be very very close, according to the room left on my car. Al. |
jimkelly |
May 27 2010, 11:54 AM
al
for all that are reading this. what is the cost to add one inch to the inside? this would cause no rubbing? what size tire would best suit this? and keep speedo accurate? jim |
Grelber |
May 27 2010, 12:14 PM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
I would be very interested in two 7 inch wides as well.
al weidman |
May 27 2010, 09:33 PM
al for all that are reading this. what is the cost to add one inch to the inside? this would cause no rubbing? what size tire would best suit this? and keep speedo accurate? jim Yes Jim, you would need a spacer. Next week I will be in Taxas for my grandson's graduation. We are going to build a few wheels in different widths and will be able to address the price question better. We, of course want to avoid using a 5 spoke Fuch to make a widened 4 spoke. Al. |
Chris Pincetich |
May 28 2010, 10:15 AM
Al, wet met briefly at the 914 Limo build (IMG:style_emoticons/default/beerchug.gif)
I am available to test wider wheels on my 914 with rear fender lips rolled to fit 205 Hoosiers. I hope I can help! (IMG:style_emoticons/default/biggrin.gif) For cruiser + Ax racers like me, 7-8" wide 4-lug Fuchs at less than 16lbs each would be tough to beat. Please weigh the wheels before and after widening. |
DanT |
May 28 2010, 11:10 AM
proper offset 7s will work on the back if they are spaced right and the fenders are ever so slightly pulled....lips rolled of course (IMG:style_emoticons/default/biggrin.gif)
like this....no reason it could not be done with Fuchs...these were 7" steelies. with this setup, I ran 1/2" spacers in the rear and 3/4" spacers up front...these are mounted with Kumho V710s, 205x50x15. Those are a very wide 205 tire. Attached image(s) |
yeahmag |
May 28 2010, 11:24 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Dan,
Where did you get your steelies made? I really like that! |
DanT |
May 28 2010, 11:26 AM
Dan, Where did you get your steelies made? I really like that! Aaron, I have no idea....I got those from Trekkor several years back, and I have no idea where he got them from... they were made with 5" back spacing and centers from a late 914 steel wheel. they worked great on my car and looked pretty decent for track wheels after I cleaned and painted them. here is a close up of them after I painted them. Attached image(s) |
yeahmag |
May 28 2010, 11:29 AM
Man... I would love a set like that! I'll have to hunt Trekkor down.
Apr 23 2017, 03:15 PM
I think we've got you covered Rich, AL. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) Al still here? What is the cost to widen four lug fuchs to 8 inches for a flared car? Deep lip, all on the outside of the wheel? |
ConeDodger |
Apr 23 2017, 06:38 PM
Apex killer! Group: Members Posts: 23,573 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I think we've got you covered Rich, AL. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) Al still here? What is the cost to widen four lug fuchs to 8 inches for a flared car? Deep lip, all on the outside of the wheel? I see both him and Harvey on Facebook more than here lately, but they do pop in... |
Lo-Fi Version | Time is now: 2nd May 2024 - 12:16 AM |
