> Oil pressure relief valve, crush washer change
TheCabinetmaker
post May 30 2010, 08:18 AM
I drive my car everyday
I've never had one leak before, but this one does. The gasket kit came with a flat aluminum washer that I used. Yesterday, while looking in my gasket box for a distributor shaft seal for my car, I found a oil valve crush type washer. My Q is: Is there oil in the relief valve cavity or does it drain back to the bottom of the case? Do I have to drain the oil to change the washer?
Thanks.
- Lo-Fi Version Time is now: 7th June 2026 - 04:47 PM
