Stud length for 5-lug conversions??, for redrilled front rotors and rear hubs |
Mueller |
Apr 8 2003, 02:32 PM
Need to order wheel studs for my 914,
Anyone know what the minimum length stud is being used?? Fronts and rears will be re-drilled stock /4 units for now. thanks, Mike |
Brad Roberts |
Apr 8 2003, 02:39 PM
What lug nut ??
B |
brant |
Apr 8 2003, 02:44 PM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Mike,
just a thought.. Studs can vary depending upon what you want to finally do with the car.... Do you want to run aluminum nuts as a street car. Or, if the project ever turns into a full race car, many orgs require steel nuts and stud sticking through.. then a longer lug would be necessary. Also, are you going to run any spacer? I just removed an measured a set of studs at 52mm, but they had a tiny bit of spacer too.. so you'll need something a little shorther. brant |
Mueller |
Apr 8 2003, 02:58 PM
These are for my "rice" rims (IMG:style_emoticons/default/smile.gif)
Not sure if open or closed lug nuts yet.... No spacers...... |
Brad Roberts |
Apr 8 2003, 02:59 PM
I'm pretty sure NONE of us can answer your question.
I need to know how thick the rim is and what lug nut you plan to run. Closed ones need X amount. B |
anthony |
Apr 8 2003, 04:04 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Mike, I bought my rear hubs from GPR. The studs they installed are marked "Verbus 10.9" and measure 50mm end to end. With a 914-6 rotor installed over the hub there is 33mm of thread exposed.
I also measured the front '86 Carrera front hubs I have. The studs are also 50mm and there is 30mm of exposed thread. |
Brad Roberts |
Apr 8 2003, 04:06 PM
Thanks Anthony... we still dont know what HE needs...LOL
50 is stock. I run 72's on the cars that will have some sort of spacers. B |
Mueller |
Apr 8 2003, 05:24 PM
Thanks for the info...I just needed a general size...
the 50mm figure should be fine, the studs available are 63.5mm so that should give me plenty of threads and then some. The rims are 16x7 with a 40mm offset, so I might have to run a 5mm spacer in the rear if tires are close to the inside fender well, but I don't think they will be.......... I'm sure in the front I'll want to run a larger spacer to move the wheels a little closer to the outside fender lip so that it looks correct Tire size will more than likely be 205/50/16's |
jonwatts |
Apr 8 2003, 06:49 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Hold the phone, Mike. I have ten of the 50mm studs from my 5-lug conversion (I put in longer studs for my 8" rims). If you give me a pittance for mine you only have to buy 6 more for a set.
Lo-Fi Version | Time is now: 7th May 2024 - 03:05 AM |
