Stud length for 5-lug conversions??, for redrilled front rotors and rear hubs |
Mueller |
Apr 8 2003, 02:32 PM
Need to order wheel studs for my 914,
Anyone know what the minimum length stud is being used?? Fronts and rears will be re-drilled stock /4 units for now. thanks, Mike |
brant |
Apr 8 2003, 02:44 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Mike,
just a thought.. Studs can vary depending upon what you want to finally do with the car.... Do you want to run aluminum nuts as a street car. Or, if the project ever turns into a full race car, many orgs require steel nuts and stud sticking through.. then a longer lug would be necessary. Also, are you going to run any spacer? I just removed an measured a set of studs at 52mm, but they had a tiny bit of spacer too.. so you'll need something a little shorther. brant |
Lo-Fi Version | Time is now: 19th May 2024 - 03:13 PM |
