Brake warning light switch reset?, Attempting to reset the brake warning light switch on "75 teener. |
skiking |
Jun 5 2010, 03:56 PM
Newbie Group: Members Posts: 23 Joined: 15-September 09 From: Rapid City Member No.: 10,811 Region Association: None |
I have read the information in this forum concerning having to reset the brake warning light switch after rebuilding the master cylinder. I've uncovered the switch in my 1975 914, and it is a single terminal with one brown wire attached. Apparently I need to remove the switch from the master cylinder to reset it? Will brake fluid come out when I do this? I'd really prefer not to have to bleed all the wheel cylinders if I can avoid it!
Thanks, Robbie |
1988Hawk |
Jun 5 2010, 04:11 PM
Newbie Group: Members Posts: 41 Joined: 17-April 08 From: Chicago Member No.: 8,929 Region Association: None |
I have read the information in this forum concerning having to reset the brake warning light switch after rebuilding the master cylinder. I've uncovered the switch in my 1975 914, and it is a single terminal with one brown wire attached. Apparently I need to remove the switch from the master cylinder to reset it? Will brake fluid come out when I do this? I'd really prefer not to have to bleed all the wheel cylinders if I can avoid it! Thanks, Robbie This switch is a button on the master cylinder, just press it and that should reset it. |
Jun 5 2010, 06:28 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
This switch is a button on the master cylinder, just press it and that should reset it. (IMG:style_emoticons/default/agree.gif) The switch is next to the wire. Sometimes, there's a black rubber cap over it. Just press it in ... (IMG:style_emoticons/default/smash.gif) Andy |
McMark |
Jun 5 2010, 07:04 PM
Brake fluid will not come out unless the seals have failed. I just swapped a broken brake warning light switch on a completely bled system with no ill effects and no fluid came out.
Lo-Fi Version | Time is now: 27th May 2024 - 11:15 PM |
