solex |
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States ![]() |
Hi,
All I just completed with the help from some people on the forum a debug of my fuel and ignition system. Turned out I need a new fuel pump, I got Bosch pump from PP and have been driving it since. I did a mini-tune up last night adjusted the dwell and timing. The car as a new air, fuel filter, plugs, Magnacore wires, cap and rotor but noticed that around 5K RPM the car stumbles. Where should I look next. Thanks, Dan |
bfrymire |
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California ![]() |
When this happened to me, it was the MAP sensor (or whatever it was called, it's been a while since i messed with D_Jet.)
-- brett Hi, All I just completed with the help from some people on the forum a debug of my fuel and ignition system. Turned out I need a new fuel pump, I got Bosch pump from PP and have been driving it since. I did a mini-tune up last night adjusted the dwell and timing. The car as a new air, fuel filter, plugs, Magnacore wires, cap and rotor but noticed that around 5K RPM the car stumbles. Where should I look next. Thanks, Dan |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
Points! Weak spring causing point "bounce".
Tom |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Points! Weak spring causing point "bounce". Tom (IMG:style_emoticons/default/agree.gif) Or stuck mechanical advance. Switch to electronics and be done with the "mini" tuneups. |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,089 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
You are just about at redline for the stock engine. Do you have the rev limiting rotor on there?
jimtab |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California ![]() |
might have "rev limiting" on the dizzy......pertronics?
solex |
No rev limiter, I believe that the coil may be on its last legs. This is one of the last things in the ignition system that I have not replaced, it is not an original Bosch blue and the last time I checked it was not putting out a healthy spark.
I just ordered a Bosch blue from PP and will report back, I think this may also fix the erratic tach. problem I have |
underthetire |
Might wanna order the compu-fire or pertronix to. Mine has a built in rev limiter- its called hydraulic lifters. (IMG:style_emoticons/default/biggrin.gif)
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,094 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
lol mine too, refuses to rev past 5k. I had my motor built with them 10 years ago when i was only using it as a daily driver. Thought it was a good idea for the first 7 years, then i started autox'ing (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Now i am doing everything I can to break something just so i have an excuse to swap back to solids. I am starting to be convinced that this engine is actually bulletproof though. 10 years of abuse and it still won't even go so far as to leak a drop of oil on the garage floor. I am cursed with a 914 that wont break!
Might wanna order the compu-fire or pertronix to. Mine has a built in rev limiter- its called hydraulic lifters. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 1st July 2025 - 02:03 AM |
