New Parts ! Door stay rollers, $19.99 for rollers $12 each for the arm til 8/15 |
Mikey914 |
Jun 13 2010, 04:53 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Whaile world has been down I've been busy.
I made the rollers for the door stay. This is the one that the ONE nylon bushing wears through and then flattens the aluminum arm. If your door rollers have not been replaced, you may want to think about it as if they haven't they may be doing damage. I have included some pictures of the process on one I rebuilt. First the damaged roller that will allow the steel to flattent the ridges on the arm. Attached thumbnail(s) |
Mikey914 |
Jun 13 2010, 04:54 PM
The damage it did
Mikey914 |
Jun 13 2010, 04:55 PM
The unit before
Mikey914 |
Jun 13 2010, 04:56 PM
Assembled
Mikey914 |
Jun 13 2010, 05:00 PM
Rollers
dem |
Jun 13 2010, 05:09 PM
Rusty Member Group: Members Posts: 147 Joined: 7-February 10 From: Cupertino, CA Member No.: 11,334 Region Association: Northern California |
are you gonna do the aluminum stay too? mine are already worn flat! or is someone already selling these cheap?
Mikey914 |
Jun 13 2010, 05:14 PM
These are done, would up being a little more work than planned $12 each
dem |
Jun 13 2010, 05:33 PM
Cool, I will wait til the door stay straps are available, then I need 2 sets. Mine are both shot.
underthetire |
Jun 13 2010, 05:48 PM
Well done, mine is shot as well.
Lennies914 |
Jun 13 2010, 06:01 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
No problem Mark, Just invoice Jeff for all and ship to me (IMG:style_emoticons/default/happy11.gif)
underthetire |
Jun 13 2010, 06:05 PM
Ha ha. I will split shipping with you, thats only fair. |
jeeperjohn56 |
Jun 13 2010, 06:12 PM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Hey Mark, I'll take two sets, one for each door when you get the door stays made also, send me a email when ready and cost. Thanks John (IMG:style_emoticons/default/driving.gif)
Mikey914 |
Jun 24 2010, 01:58 AM
Last day today for this pricing
Geezer914 |
Jun 24 2010, 06:45 AM
Geezer914 Group: Members Posts: 1,417 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I'll take a set with the door stays. Email when ready. Thanks, John
ChrisFoley |
Jun 24 2010, 09:38 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Too bad you're making a part that another member vendor already has covered.
eric914 |
Jun 24 2010, 04:04 PM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
I didn't see this till today. Can I still get two sets at yesterdays price? Email me your paypal address and i'll send $.
Mikey914 |
Jul 22 2010, 12:17 AM
I didn't see this till today. Can I still get two sets at yesterdays price? Email me your paypal address and i'll send $. No problem, i've kind of kept this open for now as it took me longer to get the stays done. You may not need the "arm" These tended to wear out on the drivers side first (big suprise), so the passenger side may only require the rollers. You could take off the door panel and shut the door to get an idea if you need the arm. It there is evidence of wear, you might want to think about it. If your wear is minimal, you could be good for another 30 years. Attached image(s) |
blitZ |
Jul 22 2010, 08:04 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I'm interested also. Is it $12 set per door? I don't see these on your website.
andys |
Jul 22 2010, 10:20 AM
I made a set of rollers a couple of years ago and quickly found that after assembly they may not rotate along the entire length of the arm if the straight knurl is worn off like in your photo. Only after I re-created the straight knurl did both rollers rotate without issue. If the rollers don't rotate, they'll probably wear very quickly and your effort may be for not.
Andys |
Mikey914 |
Jul 30 2010, 09:15 PM
I made a set of rollers a couple of years ago and quickly found that after assembly they may not rotate along the entire length of the arm if the straight knurl is worn off like in your photo. Only after I re-created the straight knurl did both rollers rotate without issue. If the rollers don't rotate, they'll probably wear very quickly and your effort may be for not. Andys I did notice that rotation is an issue. I actually lubed the shafts that the rollers are on with some grease. I also used Delrin (instead of nylon) as it has execllent wear properties. Of the 4 that I've rebuilt, I have not seen the just sliding. They are rotating. I was concerned about using grease as it could attract dirt, but it is inside the door so it's not an exposed part. These should outlast factory, and even the factory ones did last many years. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:21 PM |
