WTB: 4 bolt wheel spacers, anyone got something of interest? |
DanT |
Jun 16 2010, 08:25 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
looking for 4x130 bolt circle wheel spacers.
at least 7mm thick or thicker if you got them....preferably about 10mm what you guys got out in the garage? (IMG:style_emoticons/default/biggrin.gif) |
bdstone914 |
Jun 17 2010, 06:47 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Try your local retail auto part store like Kragen-O'Reily's. They have 1/4" universal bolt pattern spacers for about $20 a pair. I have a friend who is using this type on a race car to adjust the track.
http://shop.oreillyauto.com/ProductDetail....tegoryCode=3563 Bruce |
URY914 |
Jun 17 2010, 07:11 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Make some.
blitZ |
Jun 17 2010, 12:13 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I bought the 1/4 inch spacers from CIP1. They work well.
http://www2.cip1.com/SearchResults.asp?Cat=1263 |
EdwardBlume |
Jun 19 2010, 08:59 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I have one newer 1/4 inch spacer, and I'm fairly sure I have another one, used, around here somewhere. The bolts I bought new are slightly longer, slightly longer, than the stock fuch bolts, I have seven...
Attached thumbnail(s) |
DanT |
Jun 19 2010, 09:11 AM
Rob, those spacers should be perfect
All I will need is two of those babies and I should be good on spacing... My longer studs for the rear should work just fine. How much $? (IMG:style_emoticons/default/biggrin.gif) |
URY914 |
Jun 19 2010, 09:56 AM
Go to Home Dipshit and buy some 1/8' aluminum and make some.
DanT |
Jun 19 2010, 11:32 AM
Go to Home Dipshit and buy some 1/8' aluminum and make some. Paul, that would be great if I had access to a band saw or a lathe, which I currently do not. (IMG:style_emoticons/default/smile.gif) |
URY914 |
Jun 19 2010, 05:19 PM
Go to Home Dipshit and buy some 1/8' aluminum and make some. Paul, that would be great if I had access to a band saw or a lathe, which I currently do not. (IMG:style_emoticons/default/smile.gif) 1/8" aluminum can be cut with a $20 jigsaw with a metal cutting blade or a hacksaw. |
Lo-Fi Version | Time is now: 20th May 2024 - 01:43 AM |
