more electrical |
more electrical |
sixers34926 |
Jun 22 2010, 05:23 PM
Member Group: Members Posts: 83 Joined: 11-February 10 From: Phoenix, AZ Member No.: 11,352 Region Association: None |
RJMII |
Jun 22 2010, 05:42 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Do you have a test light? DVOM? cell phone through Verizon?
I'm almost out of minutes, but if you're on VZ I'll PM you my number and see what help I can be over the phone. |
Cap'n Krusty |
Jun 22 2010, 05:49 PM
All the engine related relays are in the engine compartment. The Cap'n
rwilner |
Jun 22 2010, 06:33 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I'm not sure what that socket does, but...
i didn't have a relay installed there when i bought the car, and the car ran just fine. I bought another relay and installed it just because. no difference |
rhd914 |
Jun 23 2010, 01:55 AM
Newbie Group: Members Posts: 44 Joined: 11-November 03 From: Australia Member No.: 1,332 |
HI, I thought that was for the buzzer to warn that you left the key in the ign with the door open.
Geoff. |
sixers34926 |
Jun 23 2010, 10:55 AM
i didnt think it had anything to do with the engine either but i just cant figure out whats going wrong with the electrical system and i was hoping it was an easy fix like a new relay or something
detoxcowboy |
Jun 23 2010, 02:31 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
was it starting before? your 3rd fuse from the right has electrical tape over the spade connection, and you have one red or 2 wires total disonnected wires with electrical tape going them.. that looks suspicious to me..
ClayPerrine |
Jun 23 2010, 02:38 PM
Life's been good to me so far..... Group: Admin Posts: 15,492 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I bet you don't have foglights on your car, do you?
I think that is the foglight relay socket. It is empty if you don't have foglights. |
rwilner |
Jun 23 2010, 07:09 PM
Mike Bellis |
Jun 23 2010, 10:43 PM
There were only so many relays that can be there, which one are you missing?
Horn Fog Key Buzzer Rear defrost If you have a cranking problem it could be the seatbelt relay under the passenger seat. |
jt914-6 |
Jun 24 2010, 05:15 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
The blank spot most likely where the buzzer goes. It has a metal cover on it. If you have a seat belt interlock realy under the passenger seat your car would be a '74 up year model. If so, connect the two large yellow wires together to bypass it.
sixers34926 |
Jun 24 2010, 10:46 AM
was it starting before? your 3rd fuse from the right has electrical tape over the spade connection, and you have one red or 2 wires total disonnected wires with electrical tape going them.. that looks suspicious to me.. Detox it was starting before but after sitting for a couple months untouched i went to start it and smoke began coming from the fuse panel. the next i went to take a look and it looked like the wire going to the 10th spot on the fuse panel was fried and melted. i was told i could just cap off that wire and it wouldnt affect the anything cuz i think it was for the fog light. so i did this and now when i turn the key nothing happens.. no lights on the dash no fuel pump no starter motor so im lost what t do next. Im only 18 and im decent with mechanical stuff but i know nothing about electrical (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 09:44 AM |
