Gulf Blue Build Thread, The build never ends |
PanelBilly |
May 7 2015, 08:51 PM
914 Guru Group: Members Posts: 5,799 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Cairo94507 |
May 8 2015, 07:10 AM
Michael Group: Members Posts: 9,717 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Man that is looking very nice. (IMG:style_emoticons/default/first.gif)
Phoenix914 |
May 8 2015, 07:19 AM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
What's with the dust on your suspension? (IMG:style_emoticons/default/stirthepot.gif) Just kidding! Your car is awesome. Mine will never be that clean.
PanelBilly |
May 10 2015, 09:14 PM
Jim came by yesterday and helped me get some more work done. We got some of the bolts in the tin on. Its one of those jobs that takes one person
above the engine and the other under. We got the transmission rod installed, but I still need to do the alignment. I got the muffler ( or is it called a final) installed and I relocated the MSD box because it was too close to the rain hat. I was hoping to get the clutch and trottle cables done, but needed to order some hardware to finish the job. Also needed to order the hard oil line that comes off the bottom of the case. |
PanelBilly |
May 23 2015, 07:07 PM
PanelBilly |
May 23 2015, 07:14 PM
PanelBilly |
May 23 2015, 07:24 PM
6freak |
May 23 2015, 08:13 PM
nice work Billy ..address that E brake cable touching the header
(IMG:style_emoticons/default/smile.gif) |
PanelBilly |
May 23 2015, 08:46 PM
nice work Billy ..address that E brake cable touching the header (IMG:style_emoticons/default/smile.gif) It's another illusion. Not touching. |
PanelBilly |
May 25 2015, 07:55 PM
PanelBilly |
May 30 2015, 05:13 PM
Got the fuel lines and filters connected today
Changed the angle of the oil pressure gauge on the block, so it is easier to read and added some hangers for the cables so they were out of the way Then i connected the clutch cable so I could figure out how much I want to have it shortened. There's a guy in town that makes cables and he said most likely he could fix it for me |
francar |
May 30 2015, 06:14 PM
Newbie Group: Members Posts: 24 Joined: 10-May 08 From: Portugal Member No.: 9,041 Region Association: None |
PanelBilly |
Jun 17 2015, 10:58 PM
I go the bolt to plug the o2 hole in the headers
and I have the battery installed, but didn't do the negative yet (IMG:style_emoticons/default/dry.gif) |
PanelBilly |
Jun 20 2015, 05:18 PM
I attached the negative side of the battery today. Headlights were backwards. Raised in the off position and lowered in the on. Easy fix. The alarm for the key in with the door open seems to be going off sometimes. I'm thinking that's one of the door switches.
Added oil. I cranked the engine over just to see if the starter worked and everything sounded normal. I need to find my spark plugs. They must be somewhere. |
turk22 |
Jun 20 2015, 08:50 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
PanelBilly |
Aug 12 2015, 10:04 PM
I thought I'd update the build thread now that the car is moving under its own power.
I installed a new exterior mirror on the driver's side. It sure is nice to be able to see what's behind me. And thanks to Bob I have a combo gauge now and I drove the car to gas station tonight. I still need to bleed my brakes and get an alignment. Front end sure is light under power and I'm thinking a corner balance will reduce that. |
KELTY360 |
Aug 12 2015, 10:34 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Outstanding! Ready for prime time. (IMG:style_emoticons/default/smilie_pokal.gif)
Larmo63 |
Aug 12 2015, 11:07 PM
Very cool thread to read and an inspiration for guys like me who are starting out on the other side of that tunnel that you are almost all the way out of.
(IMG:style_emoticons/default/beerchug.gif) |
jmitro |
Aug 12 2015, 11:28 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
unbelievable! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/aktion035.gif)
RoadGlue |
Aug 13 2015, 04:54 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Congratulations! You should be proud of this build. Look at what a beautiful car you now have. Awesome.
Lo-Fi Version | Time is now: 28th April 2024 - 07:07 AM |
