Pedal Assembly engineering, German enineering? |
arkitect |
Jun 28 2010, 10:03 PM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Finally got the 2 rusted bolts off the bottom of the pedal assembly. Nuts rusted tight, started with a cut off wheel under the car, followed up with an air hammer, they finally came off by breaking the bolts with a ratchet and a 12 point 1/2"...I know should be metric but that's what fit on a rounded off nut.
Why is everything so tight in a very tight front portion of the tunnel, couldn't the engineers come up with an more accessible design instead of the throttle cable, and clutch in a very akward position. Access panel install at front of tunnel? Dave (IMG:style_emoticons/default/dry.gif) |
arkitect |
Jun 28 2010, 11:53 PM
Sorry for the ranting, just going to be a long process, everything is a learning experience with not knowing how parts come apart.
Dave |
charliew |
Jun 30 2010, 11:21 AM
It follows a long path of vw design.
underthetire |
Jun 30 2010, 12:06 PM
It's tight for sure, but once you change cable 3 or four times (IMG:style_emoticons/default/headbang.gif) it gets a lot easier.
McMark |
Jun 30 2010, 12:09 PM
SUNAB914 |
Jun 30 2010, 12:23 PM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Better luck tomorrow. Drink a beer.
EdwardBlume |
Jun 30 2010, 12:35 PM
Better luck tomorrow. Drink a beer. Maybe the designers were waaayyy ahead of you.. (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
Root_Werks |
Jun 30 2010, 12:41 PM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Most hardware on 914's has either been tightened down for 30+ years (rusted) or over torqued by a PO. Dude, 25 feet pounds, not 250. (IMG:style_emoticons/default/rolleyes.gif) |
charliew |
Jun 30 2010, 01:43 PM
I haven't found any 30 year old car that has spent a lot of time on the road or setting outside that has easy to remove bolts.
pcar916 |
Jun 30 2010, 03:27 PM
I never do anything in that area without taking the seat out and laying a carpet over the door long. Life's too short and the seat takes 3 minutes to remove.
Lo-Fi Version | Time is now: 19th May 2024 - 04:14 PM |
