Finally got the 2 rusted bolts off the bottom of the pedal assembly. Nuts rusted tight, started with a cut off wheel under the car, followed up with an air hammer, they finally came off by breaking the bolts with a ratchet and a 12 point 1/2"...I know should be metric but that's what fit on a rounded off nut.
Why is everything so tight in a very tight front portion of the tunnel, couldn't the engineers come up with an more accessible design instead of the throttle cable, and clutch in a very akward position. Access panel install at front of tunnel?
Dave
