Guess how many HP in a 1975 1.8 ..., Got a dyno test |
Jun 29 2010, 10:12 AM
914-6 GT in waiting Group: Members Posts: 19,318 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Can't wait ? Here is the answer !!! 79 HP at about 4500 rpm. From 4500 torque begins to decrease and power stays at level. (BTW SPOKE, your guess was the closest) Gain of combined "no Catalyst converter" + "Bursh Muffler" is 6,5 HP ... Could be a few more with a new engine and better tuning. No miracles with thoses "sport" mufflers. This is the muffler I have on the car. Picture from Pelican Parts Website I bought this 914 as it is now. I didn't made any changes. The engine is supposed to have low compression pistons (did not mesure it). It also stil has those 1975 very restrictive heat exchangers. 2.0 SS heat exchanger could be an improvement for an extra 3 or 4 HP but that is a lot of money for this poor result. ... 6.5 hp is ~ 12% gain - That's good. |
blitZ |
Jun 29 2010, 10:34 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
2.0 SS heat exchanger could be an improvement for an extra 3 or 4 HP but that is a lot of money for this poor result. Having a late model car updated to earlier HEs, it's a worthwhile effort. Pretty much anything else you can do to get more HP requires cracking the case. |
Jun 29 2010, 10:41 AM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
79 HP at about 4500 rpm. I know of a 1.8L 914 that makes ~180HP, normally aspirated ... (IMG:style_emoticons/default/shades.gif) But 80HP is plenty to get in trouble on a stock 914. (IMG:style_emoticons/default/smilie_pokal.gif) Andy |
7275914911 |
Jun 29 2010, 11:41 AM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
I know of a 1.8L 914 that makes ~180HP, normally aspirated ... (IMG:style_emoticons/default/shades.gif) I want to know the blueprint?? It's all in the Heads right?? I have a 1.8 that would like to make that kind of HP without a Turbo. Come on and share some secrets..... Never dyno'ed the motor in the car but had a lot of peep after the upgrades (in sig) that I was collecting for the 2056. I also think 79 is very good # for the age of motor/injection system. |
Tom_T |
Jun 29 2010, 12:44 PM
Can't wait ? Here is the answer !!! 79 HP at about 4500 rpm. From 4500 torque begins to decrease and power stays at level. (BTW SPOKE, your guess was the closest) Gain of combined "no Catalyst converter" + "Bursh Muffler" is 6,5 HP ... Could be a few more with a new engine and better tuning. No miracles with thoses "sport" mufflers. This is the muffler I have on the car. Picture from Pelican Parts Website I bought this 914 as it is now. I didn't made any changes. The engine is supposed to have low compression pistons (did not mesure it). It also stil has those 1975 very restrictive heat exchangers. 2.0 SS heat exchanger could be an improvement for an extra 3 or 4 HP but that is a lot of money for this poor result. ... An old buddy whom I've lost track of took his L-jet 1.8 CA `75 914 & pulled what you did & added SSI 2L HE's & Banana Muffler, disconnected some of the other smog equipt. & retuned it to max. performance (not emissions limits), & was more like 88-90+ HP - IIRC (his guess-timate - although back in those days (70's) he didn't bother to dyno it). I don't doubt his estimate, because the 70-71 old un-smogged 1.7 turned out about 86 HP IIRC, so a de-smogged & larger diameter exhaust on a bigger 1.8 should be capable of 90-92 HP IMHO. His downfall was smog test time, so he sold it out of state! (IMG:style_emoticons/default/dry.gif) As long as you've pulled everything else smog-wise off it already Johannes - & since you probably don't have to meet smog tests over there - you might as well go the next step & just pick up a deal on some decent used SS 2L HEs on here, 914club, TheSamba, eBay, etc. I've been seeing some selling for around $400-600 (I got a set for $450 for my 73 2L). Then just hook the Bursch up to the 2L SS HE's & see what you get. If you do have smog checks over there, then save the HE's, converter, stock muffler, etc. to reattach & re-tune for your tests, then convert back afterwords, in between testing periods. IMHO - the bigger jump would be to convert it to more HP with the Euro-spec Carb'ed & higher compression 1.8 (don't know if the L-jet could work on the higher compr. & still pump the same HP as with carbs), but that expense is best left until it needs a motor overhaul anyway, & then the incremental expense if far less, & the wait time allows you to collect parts at bargain prices for that eventual upbuild. Ditto if your choice is to upbuild it as a bored+stroked 1900+! If this is a new 914 for you - congrats on the acquisition. You could |
nick mironov |
Jun 29 2010, 12:47 PM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
Is the "uncorrected" the HP at the tires and the "corrected" is the HP at the flywheel? If so, that shows that there is about a 30% loss in the transaxle in 5th gear at high RPMs. Nick |
johannes |
Jun 29 2010, 03:07 PM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
Is the "uncorrected" the HP at the tires and the "corrected" is the HP at the flywheel? If so, that shows that there is about a 30% loss in the transaxle in 5th gear at high RPMs. Nick That's what was mesured ... I friend of mine with a 1911cc 914 got even worse results on the transmission side. This seems to be caused by very bad alignement on the rear axle. |
johannes |
Jun 29 2010, 03:16 PM
QUOTE As long as you've pulled everything else smog-wise off it already Johannes - & since you probably don't have to meet smog tests over there - you might as well go the next step & just pick up a deal on some decent used SS 2L HEs on here, 914club, TheSamba, eBay, etc. I've been seeing some selling for around $400-600 (I got a set for $450 for my 73 2L). Then just hook the Bursch up to the 2L SS HE's & see what you get. If you do have smog checks over there, then save the HE's, converter, stock muffler, etc. to reattach & re-tune for your tests, then convert back afterwords, in between testing periods. Not that easy. I have to change all the heating setup. I don't have the stock muffler an the Bursch won't fit to the SS heat exchangers because it only fits on 75/76 setup. QUOTE IMHO - the bigger jump would be to convert it to more HP with the Euro-spec Carb'ed & higher compression 1.8 (don't know if the L-jet could work on the higher compr. & still pump the same HP as with carbs), but that expense is best left until it needs a motor overhaul anyway, & then the incremental expense if far less, & the wait time allows you to collect parts at bargain prices for that eventual upbuild. Ditto if your choice is to upbuild it as a bored+stroked 1900+!... I won't do that. event if once I change pistons and cylinders I may go for 1911cc with more compression but I will keep the Ljet. |
Drums66 |
Jun 29 2010, 03:20 PM
..Reminds me of an old car I had 1.8 w 2.0 heads......
smoking & toking 2.0's really got me High!!!! that match was'nt common back then(94') (IMG:style_emoticons/default/bye1.gif) the 1.8 is a very reliable motor. (IMG:style_emoticons/default/smilie_pokal.gif) BTW that's what I guessed(80hp) (IMG:style_emoticons/default/flag.gif) (peace out) |
charliew |
Jun 30 2010, 10:55 AM
Thats a good number. 93 octane fuel? what brand dyno? If you posted the mileage I didn't see it. To me that seems a little optimistic on a older motor and stock fi in a 75 1.8 but it will be a good starting point to go back to after changes.
johannes |
Jun 30 2010, 11:13 AM
Thats a good number. 93 octane fuel? what brand dyno? If you posted the mileage I didn't see it. To me that seems a little optimistic on a older motor and stock fi in a 75 1.8 but it will be a good starting point to go back to after changes. In France we can only have 95 or 98 octane fuel. I dont know the brand of the Dyno I didn't post the mileage. The odo shows 20.000 it can be 120.000 or more likely 220.000 The engine has been rebuilt in 1993 and has made 30.000 miles since that. As the engine has been rebuilt in California (Proshop San Rafael) I suppose that it still has low compression Pistons. Looks like this car spent most of the time in the SF aera. Was sold in Palo Alto in 75 and refurbished in San Rafael in 93 before it was shipped back to Germany. The same day a Porsche 914 with a 1911 kit and carbs was mesured at 89 HP (stock heads and cam) |
Lo-Fi Version | Time is now: 12th June 2024 - 07:47 AM |
