Fuel Evaporative Control System-AKA Charcoal Canister, More information than anyone wants to know |
JeffBowlsby |
Jun 29 2010, 01:13 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
So how does this system work? Review these first two graphics from the factory repair manual to find out.
(PS I wonder why the forced induction guys dont't use the air from the fan housing to spin their turbos? (IMG:style_emoticons/default/confused24.gif)) Attached image(s) |
Pat Garvey |
Jun 29 2010, 06:52 PM
Jeff, you know you had to open a "can 'o worms" here.
What about the older cars? I was told by the local PD (dealer) in about '75/76 that the canister was self healing, in that it would clear itself & rejuvinate itself over time - like I believed that! Charcoal has limited capabilities of absorbing hydrocarbons. Yes, it works fine for a few yeas of normal driving, but then it becomes, in the case of these pellets. over absorbed.. I suppose after that some " parked time" the pellets could clear of hydrocarbons, but would then absorb ambient moisture. Bad? Not certain, but I think so. And, when that moisture is released to the chamber & tank, corroson might occur. Now, I seem to remember that there was a maintenance bulletin that recommended changing the canister on the early cars at around 50K. By that time (one my 914) they were unavailable. So, given that my 914 is 37 years old, and isn't required to have emission testing in PA, would I be better off bypassing the canister? Is it of any value at this point? Pat |
SirAndy |
Jun 30 2010, 10:37 AM
Resident German Group: Admin Posts: 41,642 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I suppose after that some " parked time" the pellets could clear of hydrocarbons, but would then absorb ambient moisture. When i removed mine ('70 914-4), i opened it up to have a look inside. It was empty! (IMG:style_emoticons/default/huh.gif) I guess after 30+ years, all the charcoal inside had turned to dust and was happily burned by my engine ... (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Peter Zimmermann |
Aug 23 2011, 04:11 PM
Newbie Group: Members Posts: 11 Joined: 15-August 10 From: Bakersfield, CA Member No.: 12,055 Region Association: None |
I suppose after that some " parked time" the pellets could clear of hydrocarbons, but would then absorb ambient moisture. When i removed mine ('70 914-4), i opened it up to have a look inside. It was empty! (IMG:style_emoticons/default/huh.gif) I guess after 30+ years, all the charcoal inside had turned to dust and was happily burned by my engine ... (IMG:style_emoticons/default/popcorn[1].gif) Andy FWIW; this is the only suitable place I could find on my '74 1.8 (VIN 7173). There were no holes in the left side body to bring the lines forward from the shroud/air cleaner, and the car did have the 5mm plastic line in the tunnel. Result? No fuel smell at all in the car or garage. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:14 AM |
