My arduino cyl head temp display, almost got it ! |
underthetire |
Jun 29 2010, 08:42 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
My very first Arduino micro controller program. I've never used the Arduino language before ( think it c or C+ ? ) anyways, took me a few hours. Still need to order the thermocouple conversion chips, but looks like it will work. You can see when I put my finger over the analog pins, it does change as it should. Total cost will still be less than a single channel VDO gauge, and I will be able to calibrate it for more accurate readings.
https://www.youtube.com/watch?v=9UOUeEh11eg |
McMark |
Jun 29 2010, 10:39 PM
At first glance, it looks like you're looping a lot of stuff that you don't need to...
underthetire |
Jun 29 2010, 10:43 PM
At first glance, it looks like you're looping a lot of stuff that you don't need to... Its more than likely that I am. I wasn't sure if i didn't loop from the beginning of the temp set up if it would still get real time data or not. Not using any of the higher speed of the processing capability so I wasn't to concerned about it. I'll play around tomorrow and see. Like I said it was my first time programming anything like this. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:50 AM |
