My arduino cyl head temp display, almost got it ! |
underthetire |
Jun 29 2010, 08:42 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
My very first Arduino micro controller program. I've never used the Arduino language before ( think it c or C+ ? ) anyways, took me a few hours. Still need to order the thermocouple conversion chips, but looks like it will work. You can see when I put my finger over the analog pins, it does change as it should. Total cost will still be less than a single channel VDO gauge, and I will be able to calibrate it for more accurate readings.
https://www.youtube.com/watch?v=9UOUeEh11eg |
underthetire |
Jun 30 2010, 07:57 PM
Ok, got rid of the goto, your right didn't need it. Added some notes as well. Any more suggestions would be welcome (IMG:style_emoticons/default/biggrin.gif)
CODE /* The circuit: * Thermocouple amp [url=http://store.makerbot.com/electronics/electronics-kits/thermocouple-sensor-v1-0-kit.html]http://store.makerbot.com/electronics/elec...r-v1-0-kit.html[/url] * LCD keypad shield [url=http://www.robotshop.ca/dfrobot-lcd-keypad-shield-arduino.html]http://www.robotshop.ca/dfrobot-lcd-keypad...ld-arduino.html[/url] (found on ebay 7.99) * using LCD keypad shield * LCD RS pin to digital pin 8 * LCD Enable pin to digital pin 9 * LCD D4 pin to digital pin 4 * LCD D5 pin to digital pin 5 * LCD D6 pin to digital pin 6 * LCD D7 pin to digital pin 7 * wiper to LCD VO pin (pin 3) *thermocouple amp to analog pin1 (cyl1) *thermocouple amp to analog pin2 (cyl2) *thermocouple amp to analog pin3 (cyl3) *thermocouple amp to analog pin4 (cyl4) *warning to digital pin 13, also led on arduino */ // include the library code: #include <LiquidCrystal.h> void setup() { Serial.begin(19200); Serial.println("Start"); } void loop() { int raw = analogRead(1); int celsius = ( 5.0 * raw * 100.0) / 1024.0; Serial.print("Celsius: "); Serial.println(celsius); int fahrenheit = (((celsius * 9) / 5) + 32); Serial.print("Fahrenheit: "); Serial.println(fahrenheit); int raw1 = analogRead(2); int celsius1 = ( 5.0 * raw1 * 100.0) / 1024.0; Serial.print("Celsius1: "); Serial.println(celsius1); int fahrenheit1 = (((celsius1 * 9) / 5) + 32); Serial.print("Fahrenheit1: "); Serial.println(fahrenheit1); int raw2 = analogRead(3); int celsius2 = ( 5.0 * raw2 * 100.0) / 1024.0; Serial.print("Celsius2: "); Serial.println(celsius2); int fahrenheit2 = (((celsius2 * 9) / 5) + 32); Serial.print("Fahrenheit2: "); Serial.println(fahrenheit2); int raw3 = analogRead(4); int celsius3 = ( 5.0 * raw2 * 100.0) / 1024.0; Serial.print("Celsius3: "); Serial.println(celsius3); int fahrenheit3 = (((celsius3 * 9) / 5) + 32); Serial.print("Fahrenheit3: "); Serial.println(fahrenheit3); int warning =13; pinMode(warning, OUTPUT); int backlightc = 10; pinMode(backlightc, OUTPUT); digitalWrite(backlightc,HIGH); // initialize the library with the numbers of the interface pins LiquidCrystal lcd(8, 9, 4, 5, 6, 7); const int numRows = 2; const int numCols = 16; // set up the LCD's number of rows and columns: if (fahrenheit <400) digitalWrite(warning, LOW); if (fahrenheit1 <400) digitalWrite(warning, LOW); if (fahrenheit2 <400) digitalWrite(warning, LOW); if (fahrenheit3 <400) digitalWrite(warning, LOW); lcd.begin(0, 2); // Print a message to the LCD. lcd.print("Cyl. 1 temp "); lcd.setCursor(12,0); lcd.print( fahrenheit); lcd.print( "F"); lcd.setCursor(0, 1); if (fahrenheit >400) digitalWrite(warning, HIGH); if (fahrenheit >400) delay (10000); lcd.print("Cyl. 2 temp "); lcd.setCursor(12,1); lcd.print(fahrenheit1); lcd.print("F"); if (fahrenheit1 >400) digitalWrite(warning, HIGH); if (fahrenheit1 >400) delay (10000); delay (3000); lcd.setCursor(0, 0); lcd.print("Cyl. 3 temp "); lcd.setCursor(12,0); lcd.print(fahrenheit2); lcd.print("F"); if (fahrenheit2 >400) digitalWrite(warning, HIGH); if (fahrenheit2 >400) delay (10000); lcd.setCursor(0, 1); lcd.print("Cyl. 4 temp "); lcd.setCursor(12,1); lcd.print(fahrenheit3); lcd.print("F"); if (fahrenheit3 >400) digitalWrite(warning, HIGH); if (fahrenheit3 >400) delay (10000); delay(3000); } |
SirAndy |
Jun 30 2010, 10:13 PM
Resident German Group: Admin Posts: 41,654 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Any more suggestions would be welcome (IMG:style_emoticons/default/biggrin.gif) I put 'code' tags around your code ... (IMG:style_emoticons/default/shades.gif) As for the CHT display, i did this gauge mockup a few years back. I still think that would be a cool gauge to build .... (IMG:style_emoticons/default/popcorn[1].gif) Andy Attached image(s) |
Lo-Fi Version | Time is now: 24th May 2024 - 06:26 AM |
