air compressors- single vs. two stage |
Mark Henry |
Jul 7 2010, 08:25 PM
If used find a good American (or Canadian) built one. Deals can be had. New ones made in China are crap.
My compressior is WW2 surplus, 5HP 240v dual stage cast iron everything 160 imperial gallons. I've had it since 1988, bought it at action for a couple hundred bucks. It's about half the size of a 914 (IMG:style_emoticons/default/laugh.gif) |
914xprs |
Jul 11 2010, 12:09 PM
Porsche 914 parts and cars Group: NoClassifiedAccess Posts: 21 Joined: 14-July 09 From: Riverside,CA United States Member No.: 10,564 Region Association: Southwest Region |
(IMG:style_emoticons/default/drunk.gif)
i have a speedaire compressor pump with 5 hp 3 phase brand new motor(BALDOR) rTech specs: Item: Electric Air Compressor Type: Two Stage Stationary Pump Type: Pressure Lubricated HP: 5 Max. Pressure (PSI): 175 Free Air CFM @ 175 PSI: 16.5 Free Air CFM @ Max. Pressure: 16.5 Voltage: 208/230/460 Phase 3 Amps AC: 14/13.8/6.9 Tank (Gal.): 80 Tank Type: Vertical (F)NPT Outlet (In.): 1/2 Duty Cycle: 80/20 RPM: 710 On Pressure Switch Setting: 140 Off Pressure Switch Setting: 175 Enclosure: NEMA Control: Dual Motor Type: Open Dripproof Length (In.): 30 1/2 Width (In.): 24 Height (In.): 76 Includes: Initial fill of Heavy Duty Compressor Oil Oil Capacity (Qt.): 2 recently rebuilt and comes with both compressor pump, baldor motor, paid 487.00 for with maybee 10 hrs on the motor. if that, both pulleys/sieves and belt guard. no tank this is for sale @ $700.00 obo. thank you trb porsche 914 (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/birthday3.gif) parts and cars THIS ITEM USUALLY SHIPS WITHIN 10 BUSINESS DAYS YOU MUST PROVIDE US WITH A CONTACT PHONE NUMBER BEFORE THIS ITEM CAN BE SHIPPED. |
Lo-Fi Version | Time is now: 9th June 2024 - 12:07 PM |
