Welding Back Panel, The one between the engine and interior |
jaxdream |
Jul 10 2010, 03:08 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Got a patch job project to do , I've seen in the restoration threads where McMark had a similar patch project , just looking for some advice on the gap size between the two pieces of sheet metal ( cut a section out of a scraped car (IMG:style_emoticons/default/sawzall-smiley.gif) ) . This is my first time to do any body panel welding , got .024 wire on mig , voltage/amperage set on lowest setting (IMG:style_emoticons/default/welder.gif) , hasn't burned through so far on other pieces I've welded in , just want some ideas about gap size , butted up together , a tiny gap between the two ,or maybe a certain distance apart. Thanks for any replies as I do not want to screw it up rrreeeaall bad (IMG:style_emoticons/default/screwy.gif) that I can't grind it out.
Jack / Jaxdream |
Lo-Fi Version | Time is now: 18th May 2024 - 07:11 AM |
