Got a patch job project to do , I've seen in the restoration threads where McMark had a similar patch project , just looking for some advice on the gap size between the two pieces of sheet metal ( cut a section out of a scraped car ) . This is my first time to do any body panel welding , got .024 wire on mig , voltage/amperage set on lowest setting , hasn't burned through so far on other pieces I've welded in , just want some ideas about gap size , butted up together , a tiny gap between the two ,or maybe a certain distance apart. Thanks for any replies as I do not want to screw it up rrreeeaall bad that I can't grind it out.
Jack / Jaxdream
