Checking the clutch..., How best to do this?...engine and tranny are out |
slu234 |
Jul 13 2010, 11:38 AM
Member Group: Members Posts: 57 Joined: 20-January 09 From: Staunton, VA Member No.: 9,949 Region Association: MidAtlantic Region |
I have a 1970 with tail shifter. It has been sitting in a shed since 1980. I have had the engine running with the car on jack stands. Last summer I dropped the engine to clean it up and fix what needed fixin'. (IMG:style_emoticons/default/smash.gif)
I have heard that clutches can freeze up or rust to the flywheel while sitting that long. I did not think to check this while the engine was running prior to dropping it. I always started it up with the transmission out of gear. Thought I should check it out before putting the power plant back in. So, how do I check out the clutch while I have it out? Is it as simple as unbolting the transmission while on the dolly (HE's and muffler are currently off)? Any watch-out's or special tools needed and what am I looking for? Is it possible it is still OK? Thanks, Brian |
tat2dphreak |
Jul 13 2010, 12:03 PM
yep, take it apart, pull the clutch, and PP, see how everything looks, flywheel might need to be resurfaced, too... my PP was rusty too, so I replaced everything. I've always done that though, if the PP or clutch is bad, I replace it all, on any car.
914Sixer |
Jul 13 2010, 12:14 PM
Straight forward procedure. Remove the 4 bolts and the starter. Wiggle the engine and trans apart. Make sure they are as level as possible so as not to put pressure on the main shaft. If you are going this far you might as well replace the clutch fork bushing, throw out bearing bushings and trans front seal. Less than $15 total. Check throw out bearing and see if it is quite. If not, may need replacement. About $125 but shop around. Put on a dust mask and gloves for protection from dust to remove plate. Next up, unbolt flywheel bolts in crossing pattern. Remove pressure plate and disc check for wear on fingers of pressure plate and oil on disc. Check flywheel for scoring or oil. Replace rear main seal on engine. Check rear galley plugs.
slu234 |
Jul 13 2010, 12:20 PM
Doesn't sound too bad.
The car is a stock 1.7L. What clutch to use? Thanks, Brian |
Cupomeat |
Jul 13 2010, 12:35 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
I'd get a stock 6 spring 215mm Sachs unit from KEP.
tat2dphreak |
Jul 13 2010, 12:42 PM
the 6 spring 911 clutch (sachs)
Lo-Fi Version | Time is now: 18th May 2024 - 09:38 AM |
