Running /better/ than before., Still a little popping |
corsepervita |
Jul 18 2010, 02:27 AM
Member Group: Members Posts: 327 Joined: 18-April 10 From: Redmond, OR Member No.: 11,631 Region Association: Pacific Northwest |
Tonight I did the following:
- Pulled the pressure sensor and verified it held vacuum - Refreshed connections on plug for pressure sensor and input for it - Replaced multiple vacuum lines - Replaced both vacuum lines going to dizzy - Replaced both vacuum lines going to supplementary air valve (both were cracked) - Refreshed connection to supplementary air valve - Cleaned the oil bath and cleaned the flap (was sticking/sometimes not moving freely) - Cleaned contacts on throttle valve switch - Refreshed connector and plug at throttle valve switch - Cleaned throttle body, all openings, all vacuum ports on throttle body - Refreshed connection to cold start - Refreshed connection to temp feeler #1 - Adjusted throttle After this the car still has a slight difficulty starting without giving it a blip of the throttle but damn near started right off the bat. Aside from that I got only the tiniest pop and it was much better than before. Will not know till the car is warmed up and running at operating temp is this has helped tremendously or not. The throttle response either way was SIGNIFICANTLY improved and did not cough or hesitate upon giving it gas when cold like it did prior. I take that as a much better sign. It also seems to me that the intake boot where it meets the throttle body was not tightened all the way and was leaking and not sealing properly. I used a finger dab of oil around the seal where it seats on the throttle body to make a good seal and tightened it back up. Much better. (IMG:style_emoticons/default/aktion035.gif) Will try it out tomorrow night. It's almost 1:30am now. I'll piss off my neighbors if I start it up now. Also - interesting... the car came with a refurbished mps. I checked it and mine is a totally different model # than that one. I show mine ending in 003. The other ended in 022 906 051 E - now i read on the D-Jetronic parts log that the 051 E is different than my 051 (alternate # ending in 003) and is for later 70 model cars, and the 003 is for the EARLY model cars on the forums. Does this mean I cannot use the 051 E at all on mine? |
Lo-Fi Version | Time is now: 19th May 2024 - 05:27 AM |
