Newb Q's, Clutch adj? |
Cambo |
Jul 19 2010, 02:28 PM
Member Group: Members Posts: 122 Joined: 21-April 10 From: California Member No.: 11,641 Region Association: Northern California |
So, I'm getting grinding going into 1st gear and reverse. Clutch adjustment? Is there their a write up online? Is this something a mechanical idiot can do? I searched but didn't find a write up. Thanks.
dr914@autoatlanta.com |
Jul 19 2010, 02:37 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
So, I'm getting grinding going into 1st gear and reverse. Clutch adjustment? Is there their a write up online? Is this something a mechanical idiot can do? I searched but didn't find a write up. Thanks. that is the first thing that you would look at. Try tightening it up and see what happens, remembering to leave a 1/2 inch of free play. Then from there look at a stranding clutch cable, a worn ball stud cup, a broken clutch tube, a shattered clutch disc, etc. |
Cambo |
Jul 19 2010, 03:22 PM
So, I'm getting grinding going into 1st gear and reverse. Clutch adjustment? Is there their a write up online? Is this something a mechanical idiot can do? I searched but didn't find a write up. Thanks. that is the first thing that you would look at. Try tightening it up and see what happens, remembering to leave a 1/2 inch of free play. Then from there look at a stranding clutch cable, a worn ball stud cup, a broken clutch tube, a shattered clutch disc, etc. Um....are you talking about tightening the clutch cable. Sorry I'm new. Tech tips 700 is coming in the mail from AA. In the mean time, I know nothing... |
RJMII |
Jul 19 2010, 03:29 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
This is under the car, on the passenger side just in front of the axle.
The double nut system is at the end of the clutch cable, and the lever is the clutch lever. This is where you tighten your cable up. Attached image(s) |
bandjoey |
Jul 19 2010, 06:47 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
...and be sure you're at a complete stop before shifting into 1st or R. You'll grind off $25 of teeth everytime you try to shift on the roll.
If you do a search you'll find several old posts on linkage adjustment. here's a helpful link on common problems with our shifters: http://www.pelicanparts.com/techarticles/9...ift_improve.htm |
orthobiz |
Jul 19 2010, 08:18 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Dr EvilJul 29 2008, 04:34 PM Within the 1st 1/4 of travel is the 1st 1/4 of travel if you take the whole of travel and divide it by 1/4ths. So, by the time you have covered 1/4 of the total travel during depressing the pedal, the clutch should be released. Given the previous, when releasing the clutch pedal you should fell the clutch grab at about 3/4 travel on the way back up. Play refers to neutral movement. You should be able to move the pedal up and down with no resistance (it should be loose) about 3/4 inch. The pedal will ultimately rest at the low end of this travel so you should be able to pull it back towards the aft of the car 3/4". Paul |
Lo-Fi Version | Time is now: 19th May 2024 - 01:30 AM |
