engine rebuild, cost |
muncokiho |
Jul 21 2010, 06:24 AM
Newbie Group: Members Posts: 10 Joined: 14-July 10 From: Houston, Tx Member No.: 11,937 Region Association: None |
I know there are many options but just need an approx. cost of a 1.8 rebuild stock possibly with bigger p&c if possible. Should be a strait forward rebuild as the engine is low mile but sat so long the pistons are froze. Thanks,cole
EdwardBlume |
Jul 21 2010, 07:54 AM
I know there are many options but just need an approx. cost of a 1.8 rebuild stock possibly with bigger p&c if possible. Should be a strait forward rebuild as the engine is low mile but sat so long the pistons are froze. Thanks,cole A long sitting car with frozen cylinders may not be lost.... put the car in 5th and push, you'll likely hear a large pop.... |
EdwardBlume |
Jul 21 2010, 07:59 AM
Once you have the engine unfrozen... its time to replace all the fuel lines and potentially the fuel injectors...
underthetire |
Jul 21 2010, 08:15 AM
And a full rebuild is 3500-5K IMO
rallysport70 |
Jul 21 2010, 10:31 AM
Member Group: Members Posts: 64 Joined: 1-May 09 From: Albany, NY Member No.: 10,321 Region Association: North East States |
I am in the process of having my 1.8L professionally rebuilt w/2056cc pistons/cylinders, upgraded cam for $3600 cash. I expect the cost could rise slightly if any minor surprises are found. I;m keeping the original fuel injection. I'm also in no rush as I'm doing the hell hole repair, so the builder is just using it as fill in work when he's not busy.
Lo-Fi Version | Time is now: 18th May 2024 - 10:51 PM |
