Easy question for you guys..., Lower shock bolt wrench size |
MikeM |
Jul 21 2010, 11:12 AM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
What size wrench for the lower shock bolt? I don't have one big enough and have to go buy one.Car is a 74 914,2.0 liter. Cheers Mike |
Mike Bellis |
Jul 21 2010, 11:14 AM
MikeM |
Jul 21 2010, 11:42 AM
Hi all... What size wrench for the lower shock bolt? I don't have one big enough and have to go buy one.Car is a 74 914,2.0 liter. Cheers Mike Get yourself and adustable metric crescent wrench! Thanks..but I don't think so. Anyone help? Mike |
zymurgist |
Jul 21 2010, 11:44 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Hi all... What size wrench for the lower shock bolt? I don't have one big enough and have to go buy one.Car is a 74 914,2.0 liter. Cheers Mike Get yourself and adustable metric crescent wrench! Yeah, the SAE ones won't fit. (IMG:style_emoticons/default/rolleyes.gif) |
Bleyseng |
Jul 21 2010, 11:45 AM
17mm or 19mm depends
zymurgist |
6 months ago, I could have told you. But the 914 I work on is about 70 miles away at the moment.
McMark |
Jul 21 2010, 11:46 AM
It's a 27mm on both sides. I use the 27mm wrench on the nut and an adjustable wrench on the bolt. Nothing wrong with adjustable wrenches if you use them correctly. They get a bad wrap because people use them for things they shouldn't.
MikeM |
Jul 21 2010, 11:55 AM
It's a 27mm on both sides. I use the 27mm wrench on the nut and an adjustable wrench on the bolt. Nothing wrong with adjustable wrenches if you use them correctly. They get a bad wrap because people use them for things they shouldn't. Thanks McMark...exactly what I was looking for. I knew it was bigger than 24!!! |
Jul 21 2010, 12:28 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
They get a bad wrap because people use them for things they shouldn't. I'm afraid to ask ... (IMG:style_emoticons/default/icon8.gif) |
EdwardBlume |
Jul 21 2010, 12:36 PM
They get a bad wrap because people use them for things they shouldn't. I'm afraid to ask ... (IMG:style_emoticons/default/icon8.gif) Body work? (IMG:style_emoticons/default/blink.gif) |
MartyYeoman |
Jul 21 2010, 12:41 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
It's a 27mm on both sides. I use the 27mm wrench on the nut and an adjustable wrench on the bolt. Nothing wrong with adjustable wrenches if you use them correctly. They get a bad wrap because people use them for things they shouldn't. Thanks McMark...exactly what I was looking for. I knew it was bigger than 24!!! A 1-1/16" will also work just fine. |
TheCabinetmaker |
Jul 21 2010, 12:44 PM
It's a 27mm on both sides. I use the 27mm wrench on the nut and an adjustable wrench on the bolt. Nothing wrong with adjustable wrenches if you use them correctly. They get a bad wrap because people use them for things they shouldn't. Thanks McMark...exactly what I was looking for. I knew it was bigger than 24!!! A 1-1/16" will also work just fine. (IMG:style_emoticons/default/agree.gif) I use a 1 1/16 socket on the outside and big crescent on the inside. Why? Cause thats what i have! (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 02:53 AM |
