jjbunn |
Julian ![]() ![]() Group: Members Posts: 121 Joined: 20-May 09 From: Pasadena, CA Member No.: 10,383 Region Association: Southern California ![]() |
I added a console to my car, including a replacement heater lever with the correct offset handle. I was careful to attach the spade connector to it before bolting the lever down.
Now I find that moving the lever to upright doesn't turn the blower on like it used to. Also the little square illuminated blower light next to the lever no longer lights up. Before I take a close look at the circuit diagram, can anyone guess what I may have wrong, from these symptoms? Thanks! |
jjbunn |
I added a console to my car, including a replacement heater lever with the correct offset handle. I was careful to attach the spade connector to it before bolting the lever down. Now I find that moving the lever to upright doesn't turn the blower on like it used to. Also the little square illuminated blower light next to the lever no longer lights up. Before I take a close look at the circuit diagram, can anyone guess what I may have wrong, from these symptoms? Thanks! 1) Connector had fallen off in tunnel 2) Bad bulb (IMG:style_emoticons/default/beer3.gif) |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
Bet you blew the fuse.
jjbunn |
markb |
The fuse on the relay board? Have you swapped the relays around?
jjbunn |
Lo-Fi Version | Time is now: 10th June 2024 - 07:11 PM |
