frozen engine, What to use? |
jsaum |
Jul 26 2010, 10:35 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I have a 1.8 engine that came out of a 1975 parts car. The motor must have gotten some moisture in the cylinders. I pulled the head and was able to get three of the four cylinders off but am having a heck of a time with the #2 cylinder. I have the motor turned up on its side and have tried soaking it with Marvels mystery oil for a day and have also let it sit with some gas for a day. It still won't budge! Does anyone have a good trick to free up a stuck piston?
Thanks, Jsaum |
914Sixer |
Jul 27 2010, 05:56 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
PB Blaster for a couple days. Then try a little heat if necessary. If you are not saving the P&C beat on the piston top to free up the stuck rings with the end of the hammer, not the metal part.
Mark Henry |
Jul 27 2010, 07:12 AM
Diesel
There is a instant method... a hydraulic powerpack and a spark plug adapter. |
IronHillRestorations |
Jul 27 2010, 07:30 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If you've got the engine on a stand, turn it so #2 is pointing straight up, and then soak it with PB Blaster for a day or so, and hit it with a wooden block a few times to work the solvent in the cracks.
jsaum |
Jul 27 2010, 10:31 AM
I'll try the PB blaster I remember seeing it at the local FLAPS.
Thanks, Jsaum |
VaccaRabite |
Jul 27 2010, 12:31 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Try a 50/50 mix of acetone and automatic transmission fluid instead of PB. it does a much better job of freeing bound up and rusty parts. Something on the order of 200% better, if I remember the article correctly.
Zach |
Drums66 |
Jul 27 2010, 04:02 PM
Try a 50/50 mix of acetone and automatic transmission fluid instead of PB. it does a much better job of freeing bound up and rusty parts. Something on the order of 200% better, if I remember the article correctly. Zach Tranny fluid for sure!.....right on brother (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
jsaum |
Jul 27 2010, 10:55 PM
Acetone and tranny fluid, an interesting mixture! I've got it soaking over night I'll let you know how it works. Been banging on it with a wood block and hammer and tried a little heat yesterday.
Jsaum Attached image(s) |
VaccaRabite |
Jul 28 2010, 06:26 AM
Tap on it every now any again with the wood block.
The acetone will separate from the ATF over time, so it will need to be agitated every now and again. Heat helps too. Acetone is flammable though, so be careful. Not that PB or Kroil isn't. Zach |
realred914 |
Jul 28 2010, 09:44 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
just watch out the application of open flame and the flammable mixtures you are using to soak. ka boom!!!!
long soak will proabbaly do it, depend on how rusty for how long, worse case, cut teh rod and toss it, at least you can save the case! |
Mark Henry |
Jul 28 2010, 11:14 AM
You must know someone with a power pack....log splitter, tractor, car lift...a fricking grease gun might work.
Adapter can be made in minutes with an old spark plug. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:43 PM |
