Little help please |
RonnieJ |
Jul 27 2010, 03:11 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
I had a bad clutch chatter so I changed the clutch and when I first started it everything was fine it shifts great, no chatter but when I go to start it the starter turns real slow and will not start without me putting a jumper cable on and revving up the car I'm jumping from. When I do this it starts fine and runs great. I bought a new battery today because the battery was old but that doesn't seem to help...ant ideas?
TheCabinetmaker |
Jul 27 2010, 03:14 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Did you clean and reattach the ground strap on the top of the trans?
RonnieJ |
Jul 27 2010, 03:18 PM
Yes I cleaned and reattached the ground strap...Maybe it needs some additional attention. I'll try that.
underthetire |
Jul 27 2010, 03:20 PM
Did you clean and reattach the ground strap on the top of the trans? (IMG:style_emoticons/default/agree.gif) Or the cables on the starter itself. |
Drums66 |
Jul 27 2010, 03:43 PM
Did you test starter & battery? (IMG:style_emoticons/default/shades.gif)
RonnieJ |
Jul 28 2010, 03:55 PM
Thanks for the help all. I removed the grouning strap took my dremmel and cleaned up everything for a good ground, reconnected the strap and it fired on the first turn of the key.
Lo-Fi Version | Time is now: 11th June 2024 - 10:22 PM |
