RonnieJ
Jul 27 2010, 03:11 PM
I had a bad clutch chatter so I changed the clutch and when I first started it everything was fine it shifts great, no chatter but when I go to start it the starter turns real slow and will not start without me putting a jumper cable on and revving up the car I'm jumping from. When I do this it starts fine and runs great. I bought a new battery today because the battery was old but that doesn't seem to help...ant ideas?
TheCabinetmaker
Jul 27 2010, 03:14 PM
Did you clean and reattach the ground strap on the top of the trans?
RonnieJ
Jul 27 2010, 03:18 PM
Yes I cleaned and reattached the ground strap...Maybe it needs some additional attention. I'll try that.
underthetire
Jul 27 2010, 03:20 PM
QUOTE(vsg914 @ Jul 27 2010, 02:14 PM)
Or the cables on the starter itself.
Drums66
Jul 27 2010, 03:43 PM
Did you test starter & battery?
RonnieJ
Jul 28 2010, 03:55 PM
Thanks for the help all. I removed the grouning strap took my dremmel and cleaned up everything for a good ground, reconnected the strap and it fired on the first turn of the key.
