New throttle cable installing, which direction to remove? |
EJP914 |
Jul 27 2010, 05:19 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
What's the best way to remove the old cable? Pull out at the front near the pedal OR out the back at the firewall? Once out, I'm guessing I can clean out the tube it sits in w/ PB Blaster or WD40? How tough is it to get the new cable in and from what direction?
How long is the tube running thru the tunnel? I'm worried if installing cable from rear the cable end will get lost in the tunnel if the tube doesn't go most of the way. Thanks for help. Driving is a bit interesting when you back off the gas and the engine speed doesnt back off. Touch the gas pedal and the speed drops. |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:51 AM |
