Quick Wiring Questions, fog lights, horns, and cigarette lighter |
project-914 |
Jul 28 2010, 09:33 AM
Member Group: Members Posts: 181 Joined: 2-August 06 From: Oklahoma Member No.: 6,571 |
I am confused because my fogs only have one pin coming from them... but the Haynes says two wires go to it... one I assume to be the ground and the other to be the power...
also I am not sure which wires go where for the horns... I have the right wires in hand, but am not sure which pin is which. I have the same problem for the sidemarkers, turn signal lights, and the cigarette lighter. I know which wires go to which piece, just not the pin, because I see no pin numbers any ideas? a picture? thanks |
JeffBowlsby |
Jul 28 2010, 01:24 PM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
We are confused by your question too! Can you be more clear about what you are asking?
(IMG:style_emoticons/default/smile.gif) |
project-914 |
Jul 28 2010, 02:18 PM
fixed... better?
bandjoey |
Jul 28 2010, 02:24 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Brown is always ground. That help? Pelican has printable wire diagrams.
project-914 |
Jul 28 2010, 04:29 PM
I know which colors are for what, but my fogs might be missing a piece or something, I will double check it
Mike Bellis |
Jul 28 2010, 04:35 PM
Lo-Fi Version | Time is now: 16th May 2024 - 04:29 PM |
