WTB: 914 3 Pedal Assembly (or another model/brand), Clutch, Brake and Gas Pedals |
Corkus |
Jul 28 2010, 05:25 PM
Newbie Group: Members Posts: 22 Joined: 14-June 10 From: N. Calif & S. AZ Member No.: 11,834 Region Association: None |
The pedals on my 914 are trashed. Someone welded one of the pedals to the floor for some reason and I can't use them.
A 914 3 pedal assembly will work for my Subaru Conversion Project. Anyone have a 3 pedal set to sell? Or another brand of floor mounted 3 pedal assembly? PM or email me please. My email is in the signature block below. Thanks |
Gigamight |
Jul 28 2010, 08:39 PM
Member Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East |
I'm gonna jump in here...
The 914 doesn't really have a "3 pedal assembly" The gas pedal is mounted to the floor by bolts. If your previous owner welded it to the floor, there were probably some broken bolt stories behind it. I don't know if I am helping by saying this, but I have some pedal assemblies I can sell you from 914s, but you may be disappointed when you find only 2 pedals contained therein. There is an attachment on the right side where the acc. pedal attaches for the throttle cable, but no pedal. |
Corkus |
Jul 28 2010, 08:55 PM
Giga', thanks for the reply. I am interested in replacing the 3 pedals so I need to do what it takes. I am interested in buying a 2 pedal set, then.
What do I do about the accelerator pedal? PM or email me with details of what you have for sale. Thanks. |
bdstone914 |
Jul 28 2010, 10:23 PM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I rebuild pedal sets for $150. I normally get a core in exchange. There might be some usable parts from your set. I have them stripped, zinc plated and powder coated.
They are rebuilt with bronze bushings and new stoppers.You can buy a new gas pedal for about $30. Bruce |
Corkus |
Jul 29 2010, 06:49 AM
I rebuild pedal sets for $150. I normally get a core in exchange. There might be some usable parts from your set. I have them stripped, zinc plated and powder coated. They are rebuilt with bronze bushings and new stoppers.You can buy a new gas pedal for about $30. Bruce Thanks very much. That might work. I'll PM you. |
McMark |
Jul 30 2010, 01:20 AM
Just for clarity - all the 914s had the same pedal cluster, and it's the same as the one in early 911s. No need to specify anything other than 914 pedal cluster. (IMG:style_emoticons/default/biggrin.gif)
Just tryin' to be helpful. (IMG:style_emoticons/default/beerchug.gif) |
SUNAB914 |
Jul 30 2010, 09:30 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
I have rebuilt pedal clusters for $90.00 plus shipping. I will refund $30.00 if your old one is returned and rebuildable. I replace bushings with bronze bushings and replace springs as neccessary.
bdstone914 |
Jul 31 2010, 11:49 PM
Mark,
The early 911 pedal cluster is not exactly the same. The 911 upper clutch pedal is straight and the 914 is offset. This is due to the 911 having a wider wheel well. I know more about pedal sets then any normal person needs to know. Just for clarity - all the 914s had the same pedal cluster, and it's the same as the one in early 911s. No need to specify anything other than 914 pedal cluster. (IMG:style_emoticons/default/biggrin.gif) Just tryin' to be helpful. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 12:04 AM |
