New product - Trunk lights, Sign up for prebuy- some parts available now |
Mikey914 |
Jul 29 2010, 10:38 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I've decided to take on the trunk lights, I'm going to make a complete unit that has a LED bulb that will plug and play just like OEM. I looked at the LEDs as a retrofit and as they are slightly offset they didn't work well. The best choice is to redesign so that the light is focused where it's needed.
I've made the metal substructure and lens, I'm just working out the mounts. As a complete unit these will sell for $30 with the LED. I'm doing a prebuy sign up for $25. These will also have the rubber rectangular seal, just like OEM. However if you need a lens only I can sell you one at $12.50 now. Time frame is about 3 weeks to completion. Sorry things have been so slow the WAS top is consuming allot of time and resources. |
plas76targa |
Jul 29 2010, 10:54 AM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
Count me in for one of these, AND the throttle body seal on your other thread too. I'll send you a PM with a special request
Jul 29 2010, 11:00 AM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I've decided to take on the trunk lights Can you make them so they light both the trunk and the engine bay at the same time? (IMG:style_emoticons/default/popcorn[1].gif) Andy |
montoya 73 2.0 |
Jul 29 2010, 03:16 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
I've decided to take on the trunk lights Can you make them so they light both the trunk and the engine bay at the same time? (IMG:style_emoticons/default/popcorn[1].gif) Andy Good idea Andy, That would be cool! Count me in for my usual two (2). |
Mikey914 |
Jul 29 2010, 07:11 PM
Pictures added.
Yes I could set these up to light both. The only issue I see is that the plastic on the inside of the engine compartment will get dirt on it over time and may not transmit as much light. It would also require additional LEDs, so the cost would be slightly more depending on the type chosen. Attached image(s) |
Kansas 914 |
Aug 1 2010, 11:40 AM
I've decided to take on the trunk lights, I'm going to make a complete unit that has a LED bulb that will plug and play just like OEM. I looked at the LEDs as a retrofit and as they are slightly offset they didn't work well. The best choice is to redesign so that the light is focused where it's needed. I've made the metal substructure and lens, I'm just working out the mounts. As a complete unit these will sell for $30 with the LED. I'm doing a prebuy sign up for $25. These will also have the rubber rectangular seal, just like OEM. However if you need a lens only I can sell you one at $12.50 now. Time frame is about 3 weeks to completion. Sorry things have been so slow the WAS top is consuming allot of time and resources. Hi Mark, I am in for one. |
bandjoey |
Aug 1 2010, 01:21 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Add the second light in the front firewall in the engine compartment. Wire through to the firewall to the cabin light.
Aug 1 2010, 04:21 PM
Add the second light in the front firewall in the engine compartment. Wire through to the firewall to the cabin light. Why? That light already is in the engine compartment. All you would need for a fully functional engine comp light is to have that light go both ways ... (IMG:style_emoticons/default/shades.gif) Andy |
AndyB |
Aug 1 2010, 06:51 PM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
Are the LED bulbs still available for the tail lights and front turn signals?
bandjoey |
Aug 1 2010, 10:22 PM
Add the second light in the front firewall in the engine compartment. Wire through to the firewall to the cabin light. Why? That light already is in the engine compartment. All you would need for a fully functional engine comp light is to have that light go both ways ... (IMG:style_emoticons/default/shades.gif) Andy The location of the current light wouldn't throw much light on the passenger side, if a double light. Put one centered on the front firewall, and it'll throw a lot more light both ways. my 2cents. (IMG:style_emoticons/default/smile.gif) |
Mikey914 |
Aug 3 2010, 02:03 AM
nsr-jamie |
Aug 7 2010, 10:35 PM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Hi, I would be up for one too for the trial price of $ 25, sounds good to me as I am missing my light and my trunk is starting to look nice now with the new parts from everyone here. Count me in for one please, thank you too for all your help in this community!! Cheers
Lo-Fi Version | Time is now: 18th May 2024 - 03:03 AM |
