gas welding AND mig welding? |
VaccaRabite |
Jul 30 2010, 03:06 PM
En Garde! Group: Admin Posts: 13,448 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am interested in teaching myself how to weld with gas. O2 Accetiline, not MIG gas.
I have a mig welder that I am sort of competent with. Is there benefit to welding with gas over MIG, or am I going to find that if I buy the tank set up, I'll never use it over MIG. Zach |
Root_Werks |
Jul 30 2010, 03:10 PM
Village Idiot Group: Members Posts: 8,326 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Gas is really hot.
My Dad taught me on tank welding decades back. I inherited his setup about 6 years ago. Never used it, not once. I just don't do anything that can't be completed without a mig. That said, if you can weld a good bead with tanks, you can weld almost anything. It's an art controlling the flame, heat, wire etc. I welded sections of old Bugs together with tanks when I was like 14-15 years old. It was all my Dad had other than an ARC welder (Just punch holes in body sheet metal). So I had to learn. Got so good with it, I graffted in an oval window section on my 66'. Get a used setup if you can, learn it, master it and you'll be one of the few that can do it. (IMG:style_emoticons/default/welder.gif) |
Andyrew |
Jul 30 2010, 03:25 PM
I've done it once. Never used it again.
A good Mig will do everything I ever see with less heat distortion.. If I saw myself welding 1/4" steel more often then maybe I would take it up again.. But then again I'd probably just use my Arc welder... As far as my skills go. Oxy accetiline is for cutting. I own the kit, but I havent needed to use it JUST yet. Maybe when I start fabbing some more stuff for my shop, but as of now, my MAP torch gets used quite often for metal bending. Honestly, if your really curious and have the $$$, buy the stuff and teach yourself to join two pieces together just for the shear ability to say you have.. Then practice using it as a cutting torch (Really cool to hear the loud PSSHHHHHHHHH), as you will only really use it for bending metal and cuting. |
rfuerst911sc |
Jul 30 2010, 04:27 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have a oxy/acet setup along with arc and mig. To be honest for welding around the DIY garage mig is all I use. However I learned on oxy and once you master the touch I really think it makes you a better overall welder. I still use it for cutting. I haven't cranked up the 300 amp buzz box in years. Keep an eye on local Craigslist as these come up quite often around here. One thing it really is good for is heating up frozen/rusted nuts,bolts,other. You can't beat the " blue wrench " for that (IMG:style_emoticons/default/biggrin.gif) .
charliew |
Jul 30 2010, 04:41 PM
There are many good uses for a gas setup. It was the second thing I got after a wards stick welder a long time ago 1968. Get the double diaphragm regulators if you can they last longer. The trick it to turn the regulators on REAL slow to avoid blowing the diaphragm out. I use it a lot for heating thick metal to bend easier. I cut thick steel with it. I don't have a plasma cutter yet as i'm pretty sure I don't need one for the type of fabbing I do. My friend that fabs has one and he doesn't think I can justify the cost for the stuff I do. I welded a rusted out 42 jeep tub up with a torch even though I had a mig just to see if it was better. There is way less bulge in the weld bead but there was more heat put in the original metal which I think made the metal lose some of it's strength and it made it start rusting almost the next day after it was welded. You can weld aluminum with a torch. Check out John Kelly's site ghiafab I think, he's on here I think as a vender, I just ordered a new dvd from him thats his latest. He does all his auto sheetmetal with a torch I think.
http://www.914world.com/bbs2/index.php?showtopic=67022 |
rick 918-S |
Jul 30 2010, 05:15 PM
Hey nice rack! -Celette Group: Members Posts: 20,467 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
When I started out doing body work tig welders were huge money! We used to arc weld uni-body cars and gas weld unibody rails....Eeeek!
I gas weld 4130 tube. It's what the aircraft air frame guys building light aircraft recommend over tig as the rate of cooling is longer making the welds stronger. I gas weld to replicate a factory weld where it's called for. I gas weld Aluminum. Otherwise, It's nice to have a set for cutting. I never owned a plasma cutter. I am working on saving for a tig so the aluminum thing may change. I think gas welding is a lost art form. The home mig welders make it sooo easy now. |
phatnine11 |
Jul 30 2010, 05:23 PM
Member Group: Members Posts: 286 Joined: 22-March 05 From: Rancho Cucamonga, CA Member No.: 3,798 |
If you can TIG weld, Gas is a very easy to pick up. Having a OX/AC unit comes in handy when you need to apply heat. Like everone has suggested, I would look for a used PonyPac on Craigslist, doesn't take up too much room and is portable. Good luck with your welding.
Gudhjem |
Jul 30 2010, 05:36 PM
Member Group: Members Posts: 133 Joined: 29-March 07 From: Castro Valley, CA Member No.: 7,629 Region Association: Northern California |
/quick hijack
I'm in sort of the opposite situation: I'm a decent tig and stick welder, and not bad at oxy/acetelyne, but I've never Mig welded. Even though I have a Tig welder, but I've been considering getting a Mig setup since it's much faster than Tig, and I hear it generally will distort less. I'm soon going to be welding in an Engman Long kit, so thinking this might be the time to do it. Is Mig easy if you can arc and Tig weld? Do the cheap Home-Depot-type welders do well enough, or do I need separate wire feeders, etc? /Hijack off |
914werke |
Jul 30 2010, 05:57 PM
"I got blisters on me fingers" Group: Members Posts: 10,094 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
What about for Brazing?
jmill |
Jul 30 2010, 06:20 PM
If you can gas weld, tig and mig are a cake walk. I say go for it just to become a great welder. I wouldn't weld on a car with it though. It throws around way too much heat for what you need. As the others said it's great for cutting and heating up frozen fasteners.
If I was tripping over money I'd go with a tig. You can create some beautiful welds with it. |
jmill |
Jul 30 2010, 06:23 PM
/quick hijack Is Mig easy if you can arc and Tig weld? Do the cheap Home-Depot-type welders do well enough, or do I need separate wire feeders, etc? /Hijack off Mig will be easy for you. Buy a good machine with shielded gas. Make sure at least one adjustment is infinite. |
Bartlett 914 |
Jul 30 2010, 06:25 PM
Elliot Cannon |
Jul 30 2010, 08:01 PM
MIG = The "glue gun" of welders. (IMG:style_emoticons/default/lol-2.gif)
VaccaRabite |
Jul 30 2010, 08:36 PM
What does the edge of metal cut with a torch look like? Can you make precision cuts, or is it more of a ragged edge type deal?
I am going to have to cut 1/4 inch steel for my truck, and I am thinking about different ways to do it, that do not involve buying a plasma cutter. Zach |
Gudhjem |
Jul 30 2010, 09:23 PM
What does the edge of metal cut with a torch look like? Can you make precision cuts, or is it more of a ragged edge type deal? I am going to have to cut 1/4 inch steel for my truck, and I am thinking about different ways to do it, that do not involve buying a plasma cutter. Zach A torch cut on 1/4" can be very clean and straight, on one side (the off side will have crud on it), but you need to be pretty good to do that, and you'll still want to touch it up with a sander. Make sure you have the right size and a very clean tip, plus you'll need the right gas ratio, your torch at the right angle, and need to move at the right speed. Takes alot of practice or you'll end up with a jagged cut. |
Jul 30 2010, 10:26 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
A torch weld can be hammered so you can flatten it.
The mig seems to crack quickly so it cant be hammered to much. A torch heats up nuts. A torch will cut 1/4 steel and its really fun to do...and cool. You NEED this Zach....it will be the most fun you have had with fire in a long time. I did this analysis...got a torch and never looked back. I learned how to weld thick steel in an afternoon. Still learning to weld sheetmetal, bit that just takes time. Rich |
Gint |
Jul 31 2010, 07:21 AM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I learned to gas weld in high school shop class... a long time ago. I bought a used complete gas setup last year, just because it was there and cheap. $100 or so. Haven't used it at all yet. It will probably only ever get used for heating junk for reasons already mentioned here.
But I have one. (IMG:style_emoticons/default/welder.gif) And it makes really cool fire. |
aircooledtechguy |
Jul 31 2010, 08:29 AM
I only use my torch for 2 things: (1) cutting metal and (2) heating up things like rusted bolts and annealing copper exhaust gaskets. Beyond that is sits idle. Though in a small repair, restoration shop like mine where the newest cars are 30+ years old, it gets used a lot!
MIG is the only way to go with sheet metal welding. Gas welding will leave you with a part that looks like a potato chip once it cools. You can cut some pretty thick stuff cleanly especially if you use clamped angle iron as a guide for your tip. I don't see how folks can successfully work on old cars where rusted bolts are such a fact of life without a torch. As others have suggested, look at Craigslist for deals on small set-ups. No need to spend big money on something that gets used once in a while. |
charliew |
Jul 31 2010, 12:05 PM
Brazing and silver soldering has it's place in fabbing on some things that require low heat.
A lot of things used to be cut with track cutters, they were torches set up on a track to cut long cuts of almost any shape but mostly straight. The edge can be used as it is, if it is done correctly but by hand it takes a lot of practice to not have slag on the back side. Thicker metal can be cut cleaner than thinner metals. The tip must be clean so cutting rusty or coated metals will not be as clean of a cut as good clean metal. Before you buy check out a henrob they are really neat. |
76-914 |
Jul 31 2010, 09:54 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) BTW Charlie, Have you ever used a Henrob. I've seen them demo'd and thought "Holy Crap that was sudden. That stuff flowed like water but then again it was .035 and .042 aluminum skins. And I second all the other 2nds for oxy/acetylene rigs. I've had my Victor for 25 yr's. Charlie, you forgot about using the gas for "hail dent removal". (I used to live in TX). Another thing to remember. Mig is more brittle and harder to grind down. If your in a high vibration environment the gas weld is gonna hold up better (unless you've got some large ovens and a boatload of experience in heat treating.)
Lo-Fi Version | Time is now: 24th May 2024 - 12:56 PM |
