Over-revved the engine, what to look for? |
blitZ |
Jul 30 2010, 03:48 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
At the AX this past Sunday, I missed a shift and over-revved the engine. It stalled and would not restart. I assumed the worst and dropped the engine and pulled the driver's side head. I expected to see some bent valves, but it looks alright. I'm going to check the other side to be certain. I never heard any hideous noises.
What else should I be looking for in this situation? |
Bleyseng |
Jul 30 2010, 03:52 PM
I did that a few years ago and the rings were completely out of spec as the gaps were too big. Still ran but had a lot of back pressure/blowby. So I put in new pistons
crash914 |
Jul 30 2010, 05:10 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
I did that once at a track...messed up my whole weekend and 5 hour drive to the track.
Turned out that the points slipped. re-gap and check. you might be ok... |
Mark Henry |
Jul 30 2010, 05:16 PM
Look for a valve guide hammered right into the head cracking the spring boss
blitZ |
Jul 31 2010, 10:11 AM
I believe I may have found the problem. I have a Hot Spark ignition in my distributor. I tested it by using a meter and spinning the distributor and it never turns on. I also tried using a battery and light bulb, still nothing.
Is this the correct way to test a hall sensor? Thanks for the suggestions. |
Mark Henry |
Jul 31 2010, 10:50 AM
There a bunch of ways, do a google search.
Make sure you try both poles of the magnet. http://www.youtube.com/watch?v=9dHD_rwx6BY...feature=related |
underthetire |
Jul 31 2010, 10:53 AM
charliew |
Jul 31 2010, 11:08 AM
Most over reving is usually from a wrong gear selection and most of the time if there is a problem created it's a broken piston land. I don't see any way the ring gap will change though, the rings just loose their support and seal from the broken land because the ring groove is wider.
Lo-Fi Version | Time is now: 17th May 2024 - 08:09 PM |
