jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
Mounting a CHT and Oil pressure guage in a homemade panel, which will reside under dash, inside top of the jocky box in my 72. Where have you pulled 12v off of the harness to power the pressure gauge? And what have you tapped into thats switched with the light switch to light up the faces of the new gauges?
realred914 |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None ![]() |
Mounting a CHT and Oil pressure guage in a homemade panel, which will reside under dash, inside top of the jocky box in my 72. Where have you pulled 12v off of the harness to power the pressure gauge? And what have you tapped into thats switched with the light switch to light up the faces of the new gauges? use a fused source that is switched with ignition on for power to gage, The one that powers the turn, brake adn reverse lites is a good one, fuse number 9. for gage lights just dasisy chain them off the nearest instrument light on the speedo or tach, that way lites will work with teh headlihts and dimmer ahev fun |
Lo-Fi Version | Time is now: 14th July 2025 - 06:18 PM |
