Headlight switch failure/repair, Proper repair for 914 headlight switch |
bluhun |
Aug 5 2010, 05:27 PM
Member Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
My original headlight switch began malfunctioning when the beams failed to come on when the headlights popped up, unless the switch was pushed forward a hair.
The switch was replaced with a used one, which operated for a year or so when it began to malfunction in the same manner. The switch was opened and the worn contacts were resoldered, which cured the problem for a few months before the switch started failing again. The new switches are no longer available, as far as I can tell, not even from Automobile Atlanta. Does anyone have a permanent fix for this problem? |
ripper911 |
Aug 5 2010, 05:29 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
Buy a lot of used ones, you'll need them. (IMG:style_emoticons/default/head_hurts_kr.gif)
bandjoey |
Aug 5 2010, 07:47 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I'll look for a link later but I've seen an old post of modifying a vw switch that's available and cheap.
Mike Bellis |
Aug 5 2010, 10:26 PM
If you keep burning out switches, install relays to carry the load instead of the switch. Use the switch to activate the relay.
Lennies914 |
Aug 5 2010, 10:41 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
If you keep burning out switches, install relays to carry the load instead of the switch. Use the switch to activate the relay. (IMG:style_emoticons/default/agree.gif) Sounds like the proper fix to me. |
realred914 |
Aug 6 2010, 09:14 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
yes, realys!!!! that will give you brighter lights and save the switches life. when you run a relay, teh switch will last much much longer. besure to sue contact lube when you rebuild your switch. but for sure, add a set of relays to reduce the load on the switch. you will really like the brighter lights a hole lot!!!! honest!!!!
have fun |
bluhun |
Aug 6 2010, 01:37 PM
yes, realys!!!! that will give you brighter lights and save the switches life. when you run a relay, teh switch will last much much longer. besure to sue contact lube when you rebuild your switch. but for sure, add a set of relays to reduce the load on the switch. you will really like the brighter lights a hole lot!!!! honest!!!! have fun Thanks guys, I'll do that ! |
914Sixer |
Aug 6 2010, 02:49 PM
Switches do not burn up unless they are being overloaded. Are you burning up fuses? The lights all have fuses on the fuse panel.
bandjoey |
Aug 6 2010, 05:37 PM
My switch didn't burn up, and doing a light switch search, found a lot of switches just break up inside. The detent springs on mine broke, and the crud caused the insides to slowly grind away until it was no good. Turn it upside down, and look at the chunks of bakelite and springs fall out.
bandjoey |
Aug 6 2010, 07:04 PM
Here's the only link I could find on a vw replacement part. Not a lot of description but tells us what needs to be done. A good electrical mechanic should set up an adaptor from the old wires to the new plug . With the cheaper part, it'd probably sell.
http://www.914world.com/bbs2/index.php?sho...=45370&st=0 |
Marlow |
Aug 7 2010, 09:04 AM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
This might help for the VW switches. Output diagrams of a bunch of different VW headlight switches.
http://www.oldvolkshome.com/headlight_switch_OVH.pdf |
Lo-Fi Version | Time is now: 16th May 2024 - 01:48 AM |
