Ghost wipe |
Ghost wipe |
partwerks |
Aug 7 2010, 09:45 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
For the ghost wipe on the wipers I first cleaned the grounds, but that didn't help and tried another relay with no success.
It may go several minutes when in the off position and out of the blue the intermittent wipers/3rd speed, will come to life for some strange reason. I wonder what's up with that?? |
jsaum |
Aug 7 2010, 11:35 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
For the ghost wipe on the wipers I first cleaned the grounds, but that didn't help and tried another relay with no success. It may go several minutes when in the off position and out of the blue the intermittent wipers/3rd speed, will come to life for some strange reason. I wonder what's up with that?? I'm not an electrical expert but if the wipers are coming on with the switch in the off position intermittently then I would think the positive circuit is seeing a ground/ negative that is completing the circuit to cause the wipers to actuate. Jsaum |
Aug 8 2010, 01:11 AM
Resident German Group: Admin Posts: 41,626 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
For the ghost wipe on the wipers I first cleaned the grounds, but that didn't help and tried another relay with no success. It may go several minutes when in the off position and out of the blue the intermittent wipers/3rd speed, will come to life for some strange reason. I wonder what's up with that?? I had the same issue with my intermittent wipers. I removed the intermittent relay and all is good now. (IMG:style_emoticons/default/shades.gif) Andy |
914Sixer |
Aug 8 2010, 06:17 AM
914 Guru Group: Members Posts: 8,878 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check to make sure the screws in the steering column that holds the TS and wiper switch are tight.
detoxcowboy |
Aug 8 2010, 09:19 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Just to clarify "off" is the second to last stop pulling down on the switch.. the last stop are the delay "ghost" position
That being the case, with delays working in that postion for "several Minutes" then I assume they stop? and occasionally out of the blue for no reason your high speed (3rd up) come on? I would check the brown wire in the switch and the switch contacts.. brown is ground and the switch is ground operated. no of those being loose or broken contacts.. then more than likely your relay is tired and failing.. This only assumes they used to work properly and have not recently been re-wired or pump installed with related wiring ect./. Probably the easiest is just try another relay.. if that solves it you do not havbe to dig your switch out for nothing.. |
jim_hoyland |
Aug 8 2010, 11:32 AM
Get that VIN ? Group: Members Posts: 9,278 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I get mystery wipes too, after pulling the intermittant and reinstalling, the ghost wipes dissappear.
76-914 |
Aug 8 2010, 12:02 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC, mine was that same brown wire (maybe w/ a white stripe) but it was the spade that was pushing out of the socket where the intermitant relay plugged in.
underthetire |
Aug 8 2010, 12:53 PM
Since i only have normal wipers, not 3 speed, I may be talking out my tailpipe, but how about the zero or rest position switch inside the wiper assembly? Could it be loosing that cycling one more time ?
partwerks |
Aug 8 2010, 04:55 PM
Since i only have normal wipers, not 3 speed, I may be talking out my tailpipe, but how about the zero or rest position switch inside the wiper assembly? Could it be loosing that cycling one more time ? It works fine in speed 1 and 2 and intermittent. It only has the intermittent ghost wipe when it is in the off position which is 1 up from all the way down. Is the switch you're talking about, inside the motor? Also, the other idea, is there maybe a spade that is pushing out of the bottom where the relay pushes in? Is that what you are saying? I tried another used relay and same problem. Unless it is shot also, but not too likely. Also, I don't recall on how to get the ends of the wires out of where they clip in at. I thought they had a barb on them and you just pushed something like a screwdriver in and they would just pull back out so I could clean up the grounds where the realy plugs in and start theyre to see if that helps any. Another enthusiast thought it could be the stalk control in the steering wheel hub that could be cracked. I have no idea what that part even looks like. Anybody have a picture of it?? |
Aug 8 2010, 05:32 PM
It only has the intermittent ghost wipe when it is in the off position which is 1 up from all the way down. Like i said, same happened to me. Since i don't drive in the rain, i just took out the intermittent relay. (still have the normal wipers function) It's definitively related to the intermittent circuit. (IMG:style_emoticons/default/shades.gif) Andy |
realred914 |
Aug 9 2010, 08:32 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
whitch cars came with intermittant wipers? none of mine has them. is this aftermarket?
Aug 9 2010, 10:42 AM
whitch cars came with intermittant wipers? none of mine has them. is this aftermarket? Factory option. Came with it's own wiring harness, relay socket and relay. There's a thread somewhere, i believe in the "Originality and History" forum. (IMG:style_emoticons/default/shades.gif) Andy |
914Sixer |
Aug 9 2010, 03:41 PM
Did you check the screws in the steering column as I said in the PM?
partwerks |
Aug 9 2010, 08:56 PM
Not sure how far I'll get, as I don't have the 27 MM socket to fit, unless a less than desireable crescent wrench would work/fit in the opening?
914Sixer |
Aug 10 2010, 06:41 AM
Crescent not likely to work unless wheel has been off before. Try some late SAE sockets if you have them.
Sleepin |
Aug 10 2010, 12:47 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Sooo.....after sitting here looking at the title of this thread for a week, I have to wondering...wouldn't it streak his sheet?
(IMG:style_emoticons/default/lol-2.gif) Attached image(s) |
76-914 |
Aug 10 2010, 09:16 PM
This might be reaching but those wires pass under and around the plenum or air distribution box. As you can see there is virtually no room there and there are a few cables routed under there, also. There could be a bare spot and you wouldn't see it. IIRC there was a ground on the motor body that I wasn't impressed with so I jumpered that to a chassis ground. Check that connection, too.
partwerks |
Aug 14 2010, 07:30 PM
After getting the wheel off, I soon discovered that all 4 screws were totally loose.
After getting it all put back together, so far, so good, no ghost wipe, so apparently that was the whole problem with the intermittent. Thanks for the tip! |
jim_hoyland |
Aug 15 2010, 08:48 AM
After getting the wheel off, I soon discovered that all 4 screws were totally loose. After getting it all put back together, so far, so good, no ghost wipe, so apparently that was the whole problem with the intermittent. Thanks for the tip! Yup ! Two of mine were loose too, retightened them with locktite and haven't had a ghost wipe yet (IMG:style_emoticons/default/smile.gif) Thanks for digging into this, it's been a running topic for a long time |
Bartlett 914 |
Aug 15 2010, 11:56 AM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
There is a ground screw on the switch. It is grounded using the mounting screws instead of a pin in the connector. Just the same, it part of the circuit. When in the off mode, this is connected to the Brown / Black wire and holds that wire at ground. In the intermittent mode this connection is open! This allows the brown / black wire to float. When open you will have intermittent wipers (if the relay is installed).
I did some testing with intermittent wipers on the bench and this gave me some grief. To make matters worse, I was using a steering column from a project car. This column has the 4 bosses where the switched are screwed in place. On this column, the boss that provides the ground connection is lower than the other 3. I would never get a the wipers to turn off. They were stuck in intermittent mode even with the screws tight. When I get around to using this column, I will need to add some washers under that screw to make the connection. |
Lo-Fi Version | Time is now: 11th May 2024 - 03:40 AM |
