QUOTE(underthetire @ Aug 8 2010, 10:53 AM)
Since i only have normal wipers, not 3 speed, I may be talking out my tailpipe, but how about the zero or rest position switch inside the wiper assembly? Could it be loosing that cycling one more time ?
It works fine in speed 1 and 2 and intermittent. It only has the intermittent ghost wipe when it is in the off position which is 1 up from all the way down.
Is the switch you're talking about, inside the motor?
Also, the other idea, is there maybe a spade that is pushing out of the bottom where the relay pushes in? Is that what you are saying?
I tried another used relay and same problem. Unless it is shot also, but not too likely.
Also, I don't recall on how to get the ends of the wires out of where they clip in at. I thought they had a barb on them and you just pushed something like a screwdriver in and they would just pull back out so I could clean up the grounds where the realy plugs in and start theyre to see if that helps any.
Another enthusiast thought it could be the stalk control in the steering wheel hub that could be cracked.
I have no idea what that part even looks like. Anybody have a picture of it??
