F/S Pro-Built Engine 2.7 |
carr914 |
Aug 10 2010, 05:26 PM
Racer from Birth Group: Members Posts: 118,670 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Want to be the fastest car in your neighborhood or local track?
For Sale: Professionally Built 2.7 Six Cylinder engine ( ZERO Miles) Mag 7R case - all machine work done at J-B Racing (over $2,000) Carrera RS Pistons & Cylinders Goetze Piston Rings Polished Crank All new Bearings ARP Rod Bolts Machined Head Seal Surface ( Decked for higher compression - can still use PumpGas)) All new Valves, Valve Springs, Hardware Cylinder Head Work, Valve Job, Guides replaced Web 158R 4 Bearing Cams Four Bearing Cam Houses New Chains, Rails, Tensioners etc New Oil Return Tubes Rebuilt Weber Carbs ( Bieker) PMO Tall Intakes K&N Filters with RainShields ( will be replacing the Custom Carr914 Shields) New Valeo Alternator from Pelican (internal Regulator) Everything except an Oil Cooler Builder projects motor to make 240HP based on other similar builds $15,000 - Will sell without Carbs if requested |
BMXerror |
Aug 10 2010, 08:40 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Britain! Look! You said you needed more horsepower. (IMG:style_emoticons/default/biggrin.gif)
Mark D. |
koozy |
Aug 11 2010, 01:23 AM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
I believe Brit's engine is just about the same as this one.
ArtechnikA |
Aug 11 2010, 05:30 AM
Very tempting...
I know I would be time and money ahead of the game (if 50 HP down) to do this instead of proceeding with my build. But that $20k step is a big one - mine is more like baby steps as the money trickles out instead of leaving in a big gulp... Questions - no hurry on answers... No flywheel, yes? Webers - 40's or 46's ? Stock 2,7 rods ? Original head studs ? Original 2,7 oil pump or something newer/updated ? What's the 158R cam 'like' - E, S, Solex ... ? I've got a bookmark to the Web Cam site somewhere but I'm just looking for a ballpark characteristic... If we get closer I'd want to know more about the case work, but at the moment I just have my nose pressed to the storefront glass... |
carr914 |
Aug 11 2010, 07:12 AM
No I don't have a good Flywheel ( at least I don't think I do, I know I have one with no life left in it)
Webers are 40's rebuilt by Bieker. I think 46's would be way too much. I've got PMO 46's on my 2.8 Twin-Plug. Stock 2.7 Rods that were examined & polished New Studs when Case work was done 3.2 Oil Pump The Cams are ones that I traded my builder for when I converted to 4 Bearing Cam Houses. I will have to get with him for the profiles. I may have a Dizzy - I have to dig. I will be more than glad to put you in touch with my Builder to discuss the Case work or the build itself. Probably the most prominent Engine Builder on Pelican. And like you said, you will be money & TIME ahead. There is a guy on Pelican selling 2.7 engine parts that when totalled come out about $13k, but then you have to do case work, head work, buy more parts and do installation. T.C. |
ArtechnikA |
Aug 11 2010, 08:04 AM
No I don't have a good Flywheel de nada. Got a couple. Just asking 'what's in the box' ... QUOTE Webers are 40's rebuilt by Bieker. I think 46's would be way too much. I think so too - hadda ask. 2,8RSR is the engine i'm building. Got a pair of 46's to run while I save up for the full-tilt MFI setup...QUOTE New Studs when Case work was done Factory? ARP? Something else ? QUOTE The Cams are ones that I traded my builder for when I converted to 4 Bearing Cam Houses. I will have to get with him for the profiles. profiles be nice but no panic hurry. Have the rockers been run-in with those cams? resurfaced? New? QUOTE I may have a Dizzy Got a '75S dizzy that'd at least get it run in and putt around town. QUOTE Probably the most prominent Engine Builder on Pelican. That could be any of them, to hear them tell it ;-) QUOTE And like you said, you will be TIME ahead That's really all that makes it tempting, frankly. $20k in a lump vs an equivalent amount spread out over a while. I will be totalling up the receipts but I don't think my build will be much if any more than that... |
carr914 |
Aug 11 2010, 10:02 AM
Studs are Porsche Steel units
WebCam is not open for another hour, but according to their Website 158 Valve Lift .450/.400 Duration 250/240 Duration @ 0.050 232/222 My Engine Builder has building Porsche Race motors for longer than I have known him ( > 25 years). He is the Engine Room Manager at one of the finest shops in the country. He has built a Type IV that I couldn't kill, a 2.5 Twin-Plug, my 2.8 Twin-Plug and this motor. His motors are in HSR, IMSA cars. He has a 962 motor on his bench right now. The Case work included; Shuffle-Pinned Oil Mods Screw-in Piston Squirters Time certs/ Case Savers I could deliver to PA for some gas money ( not much, the motor will fit in my Honda Civic hatchback) as I do need to see my Mom who is in a Home in Upstate NY with Alzheimers. T.C. |
ArtechnikA |
Aug 11 2010, 10:10 AM
I could deliver to PA for some gas money ( not much, the motor will fit in my Honda Civic hatchback) as I do need to see my Mom who is in a Home in Upstate NY with Alzheimers. delivery is the least of my worries... it's just a huge chunk of change. I can get away with spending $1000 a month for 20 months on parts. $20k in one month isn't in the picture any time soon... Maybe after we refinance the place... Either way, you're welcome to stop over on your trip up and or back - the guest room is available. Joy specializes in geri care (DON at a 140-bed facility in Quakertown) and has run an ALZ unit. |
carr914 |
Aug 16 2010, 08:30 AM
Rich & others,
I have an offer on the motor that I'm considering (IMG:style_emoticons/default/confused24.gif) , so there is still a small window of opportunity for someone to get in under the wire. T.C. |
carr914 |
Aug 25 2010, 01:47 PM
carr914 |
Aug 27 2010, 04:12 AM
New Lower price exclusively for the World. I think $20K scared off some people. And I have had Two Deals go Sour.
I have my 2.8 Twin-Plug motor (if someone wanted that, I would take an offer of over $50K) arriving from the same builder very soon. I need my engine stand for that. Also I'm going to buy a car from a fellow member here, so I need the $$ too complete that deal. Crateing & International Shipping Available Can deliver as far as Atlanta (during Petit LeMan week) Here is the Cam Card with full info |
carr914 |
Sep 1 2010, 12:22 PM
The Motor
Back up For Sale, The Race Car is going T.C. |
URY914 |
Sep 1 2010, 07:12 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,618 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
This must mean you are now able to afford a race car somehow?
carr914 |
Sep 1 2010, 07:41 PM
Paul, Still waiting on my other deal. But you are getting to far ahead of me in pictures that I have to try to give you some competition on the track. (IMG:style_emoticons/default/driving.gif)
Plus I think I have enough parts to build 3 race cars T.C. |
URY914 |
Sep 1 2010, 07:58 PM
Bring it on.... (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/first.gif)
carr914 |
Mar 10 2011, 09:36 AM
Just got too much on my Plate so the Motor is Back up For Sale @ a Lower Price
$15k or BO T.C. |
porbmw |
Mar 10 2011, 05:01 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
carr914 |
Mar 10 2011, 06:46 PM
Today's pm's answered
T.C. |
porbmw |
Mar 10 2011, 11:34 PM
carr914 |
Mar 11 2011, 05:21 AM
Sale Pending
Lo-Fi Version | Time is now: 17th May 2024 - 05:56 PM |
