Want to be the fastest car in your neighborhood or local track?
For Sale: Professionally Built 2.7 Six Cylinder engine ( ZERO Miles)
Mag 7R case - all machine work done at J-B Racing (over $2,000)
Carrera RS Pistons & Cylinders
Goetze Piston Rings
Polished Crank
All new Bearings
ARP Rod Bolts
Machined Head Seal Surface ( Decked for higher compression - can still use PumpGas))
All new Valves, Valve Springs, Hardware
Cylinder Head Work, Valve Job, Guides replaced
Web 158R 4 Bearing Cams
Four Bearing Cam Houses
New Chains, Rails, Tensioners etc
New Oil Return Tubes
Rebuilt Weber Carbs ( Bieker)
PMO Tall Intakes
K&N Filters with RainShields ( will be replacing the Custom Carr914 Shields)
New Valeo Alternator from Pelican (internal Regulator)
Everything except an Oil Cooler
Builder projects motor to make 240HP based on other similar builds
$15,000 - Will sell without Carbs if requested
