Upside of a scissor lift |
scotty b |
Aug 10 2010, 07:13 PM
Makes unfolding a 914 a lot easier (IMG:style_emoticons/default/smile.gif) The nature of the scissor lift puts all of the support back into the car once it is off the ground. Note in the pics the original door gap, and how the door has begun to droop, and once I ran the lift up, the gap opened back up and the door raised back into it's proper position. Measure everything and install bracing while in the air, dropped it down and all stayed in place (IMG:style_emoticons/default/biggrin.gif)
Krieger |
Aug 10 2010, 08:03 PM
Advanced Member Group: Members Posts: 4,706 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Millimeters matter!
EdwardBlume |
Aug 10 2010, 08:20 PM
charliew |
Aug 13 2010, 06:44 PM
I think it needs a little more, the stripes and the handle pocket looks a little low still but you can fix it with the brace. The lift does give a lot of help though. Maybe a poboy could use a long 4x4 on each side with a floor jack under each side and one at the front in the center to get the same results.
Spoke |
Aug 14 2010, 06:52 AM
Excellent.
Maybe you should post this in the Homemade Tools thread. Not really a homemade tool but a way to use a tool meant to lift a car to use it for aligning a 914 chassis. BTW, Nice looking car there. Love the yellow. I have a yellow 914 too except its got a outer coat of red on it. (IMG:style_emoticons/default/lol-2.gif) |
qa1142 |
Aug 14 2010, 06:58 AM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
I want one so bad, I looked at very nice used one 3 years ago for $600 should have jumped then.
Someday... Just not having to bend down all the time (IMG:style_emoticons/default/poke.gif) |
McMark |
Aug 14 2010, 11:55 AM
That's awesome! (IMG:style_emoticons/default/thumb3d.gif)
RFoulds |
Aug 14 2010, 06:08 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
Would love one. Can't even find one to rent around here. How much should I pay for a used one in good shape??
pete-stevers |
Aug 14 2010, 06:31 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
but look at the foot print, doesn't the support steel on the ground get in the way?
iamchappy |
Aug 14 2010, 07:15 PM
On mine and i think Scotty's one side is open.
Lo-Fi Version | Time is now: 10th May 2024 - 08:36 AM |
