Motor Won't Turn Over Fast Enough |
adambo |
Aug 11 2010, 12:14 PM
Newbie Group: Members Posts: 25 Joined: 8-September 09 From: Boulder, Colorado Member No.: 10,776 Region Association: Rocky Mountains |
Hey I just did a full rebuild and now when trying to start it up, with a fresh battery, it turns over but super slow. Jumping doesn't help. Could it be a problem with the motor itself? Or starter?
-Adam |
Kirmizi |
Aug 11 2010, 12:16 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
How are your grounds? Especially the one between the transmission and body?
Mike |
realred914 |
Aug 11 2010, 12:18 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Hey I just did a full rebuild and now when trying to start it up, with a fresh battery, it turns over but super slow. Jumping doesn't help. Could it be a problem with the motor itself? Or starter? -Adam well you could confirm what voltage y9u have at the starter when you crank. confirm you have the ground strap re-attached on the tranny to body for sure. check any other connections you might have moved also. the motor might be super tight, try cranking with the sparkplugs removed, does it get better? if not, then suspect the probelm is more likely the starter/starter power than a tight motor. goodluck |
dr914@autoatlanta.com |
Aug 11 2010, 12:34 PM
914 Guru Group: Members Posts: 7,846 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
RonnieJ |
Aug 11 2010, 12:56 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
I just went through the same thing when I changed my clutch. I reconncted the grounding strap but evidently didn't have a good ground. I disconnected the strap and took my dremmel tool and cleaned everything up reconnected the strap and it started like a champ.
adambo |
Aug 14 2010, 01:50 PM
I cleaned up my grounds and I'm getting a little over 12 volts at the starter. I pulled the plugs and it turns over faster but not nearly fast enough. Also with the plugs out and tranny in gear I can't push the car, even with two guys.
Thanks again -Adam |
Tom |
Aug 14 2010, 01:59 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
If jumping , a good battery, grounds rechecked, and still doesn't help cranking speed, you must have a problem with some of the turning gear. by that I mean clutch, pressure plate, trans, fan on the front on with too long of a bolt, something that would cause the flywheel to turn slowly. You probably should start checking clearances now before you damage something.
Tom |
Lo-Fi Version | Time is now: 11th May 2024 - 07:11 AM |
