9 Pages V < 1 2 3 4 > »
> Red Rock or Bust!, 914 Car-B-Q
majkos
post Aug 11 2010, 09:18 PM
Post #21
I admit, engine grill for grilling would be too kool.
But we've all this shallow space perfect for grilling
Look what I found in the trunk!
majkos
post Aug 11 2010, 09:19 PM
Post #22
Space, perfect for grilling
Sleepin
post Aug 11 2010, 09:27 PM
Post #23
I would think to either make the trunk lid removeable with pins, or open from the side, gangsta style. I dunno, Gregor has a point.
Found this: http://www.doityourself.com/stry/qnatrucks4
First, a warning. Although pick-up box trailers are cheap and easy to make, they are one poor trailer unless they are properly rigged. The biggest problem is the fact that the wheels are smack dab in the middle of the box. When you load the thing and go over a bump, the trailer tends to whip because of there being no weight or negative weight on the ball. You need to have the wheels behind the centerline of the box to about 60 percent in front and 40 percent in back for it to handle safely. If you use the original axle, you must keep the gears together so that the front seal can keep the gear oil in. Some have removed the gears and made a plate for the front opening to keep the oil in. Those bearings can't run dry. The truck axle will probably work fine, it will just be heavier than the lighter beam axle. You can always strip the brakes off to make it a little lighter.
http://www.bestcarsguide.com/how-to-build-...-trailer-guide/
http://www.championtrailers.com/UTILITY_TRAILER_KITS.HTM
brant
post Aug 11 2010, 09:29 PM
Post #24
nice looking top in there!
majkos
post Aug 11 2010, 09:36 PM
Post #25
Alum. skin mock up
majkos
post Aug 11 2010, 09:38 PM
Post #26
Plenty of room
majkos
post Aug 11 2010, 09:44 PM
Post #27
Mike, up in Windy Wyoming, Good eye!
But my Sam's deal went belly up last fall.
Eric, I agree on the aero part, that's why I'm going w/o the window (IMG:style_emoticons/default/biggrin.gif)
Sleepin
post Aug 11 2010, 09:48 PM
Post #28
Seems like every place I read, they say that you want 60% weight on the tongue side and 40% on the axle side, otherwise she will sway. Something to think about when doing the layout.
Gint
post Aug 11 2010, 10:10 PM
Post #29
Mike Ginter
Hey Kevin... Did you see this from Rick:
QUOTE(rick 918-S @ Aug 11 2010, 07:36 PM) *
Is that a 2" section of square tube? I may have a 2" hitch that fits that tube.
If that's 2" square tube, let Rick know.
majkos
post Aug 11 2010, 10:14 PM
Post #30
QUOTE(Sleepin @ Aug 11 2010, 07:48 PM) *
Wouldn't independent suspenion make a differnce?
The KYG's gotta go, crap anyway
I think the 100 lbs springs are in there (upgrade)
majkos
post Aug 11 2010, 10:15 PM
Post #31
QUOTE(majkos @ Aug 11 2010, 06:58 PM) *
Rick 2" outside to outside
I did (IMG:style_emoticons/default/biggrin.gif)
Sleepin
post Aug 11 2010, 10:25 PM
Post #32
QUOTE(majkos @ Aug 11 2010, 10:14 PM) *
Not sure if the IRS will help or hurt in a trailer application. I don't think it would affect it negatively, because we are looking at what 600lbs or so?
majkos
post Aug 11 2010, 10:51 PM
Post #33
600 lbs!
dude I don't think it weigh more than 300 maybe 400
rick 918-S
post Aug 12 2010, 12:01 AM
Post #34
Hey nice rack! -Celette
QUOTE(majkos @ Aug 11 2010, 11:15 PM) *
PM me your Address and I will drop it in the mail.
Sleepin
post Aug 20 2010, 09:20 AM
Post #35
Hey Kevin! We need an update!
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-8357-1282155860.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/strangecosmos.com-8357-1282190273.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/strangecosmos.com-8357-1282190274.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/strangecosmos.com-8357-1282190275.3.jpg)
majkos
post Aug 20 2010, 05:10 PM
Post #36
Sweet!
I love the drawer pull out grill.
majkos
post Aug 22 2010, 09:10 PM
Post #37
The latest,
majkos
post Aug 22 2010, 09:11 PM
Post #38
another use,
majkos
post Aug 22 2010, 09:23 PM
Post #39
The "engine" compartment (IMG:style_emoticons/default/biggrin.gif)
Sleepin
post Aug 22 2010, 09:48 PM
Post #40
Hurry Kev! (IMG:style_emoticons/default/wink.gif) Looking good man!
- Lo-Fi Version Time is now: 9th June 2026 - 12:07 AM
