Fuel Filters? what on earth do i use?, or does it matter as long as it filters? |
red914 |
Apr 12 2004, 06:33 PM
...i believe in coyotes and time as an abstract... Group: Members Posts: 862 Joined: 8-February 04 From: poulsbo, washington Member No.: 1,641 |
actually, a couple questions. first, i need to replace the fuel filter. it is a round, black unit, with little squeeze clamps holding the rubber fuel line on each end. it didn't look anything like any of the fram filters at schuck's. as long as the filter fits the line, does it matter (resistance to flow sorts of factors) what size the filter is? does size matter? (IMG:style_emoticons/default/confused24.gif)
second, and this just occured to me over the weekend: how can i know what size engine i have? it is a 1.7, i think. at least that is what the previous owner told me, and he was a pretty honest guy. i wish i had a digital camera, because i know that if i posted pictures of the fuel filter and the engine, members could tell me. |
Mark Henry |
Apr 12 2004, 06:58 PM
What size are the lines in/out?
If they are 8mm/8mm then use a VW part# 311 133 511C or if it's a 8mm/10mm then use the '76-'83 VW bus filter (no number handy). They are square but they work. |
Apr 12 2004, 08:21 PM
If you have fuel injection, use the high-pressure and high-flow FI fuel filters. Available from your favorite on-line vendors and elsewhere. (See my sig below for my favorite vendor.)
If you have carbs, probably just about any filter that fits will be OK. Check for an engine serial number. Look on the right-rear part of the top of the crankcase. It's often obscured by dirt. One that starts with "W" or "EA" is a 1.7 crankcase, though you can build any-displacement 914 engine on any 914 crankcase. The 1.7 is the smallest 914 engine, so it's unlikely someone would lie about a car having that. --DD |
red914 |
Apr 12 2004, 08:52 PM
i knew i would get some scoop. thanks. (IMG:style_emoticons/default/pray.gif) i should have mentioned it has a single solex carb. the lines going in and out are the same size; 8mm sounds about right. nothing so substantial as 10mm. is bigger better?
i will look for the "vw" or "ea" on the case. i doubt the PO would make it up. also, it doesn't have the neck snappig acceleration that i hear the 2.0 cars have. (IMG:style_emoticons/default/wacko.gif) another question: how difficult is it to do one of those "move the fuel pump to the front, away from the hot ol' engine" jobs? does it help out? |
campbellcj |
Apr 12 2004, 09:32 PM
I have a factory 914-6 filter up front near the tank and pump, and I also just put a small inline AN-6 Russell filter immediately before the Webers. No clogged jets thus far...
Mark Henry |
Apr 13 2004, 06:32 AM
QUOTE(red914 @ Apr 12 2004, 06:52 PM) i should have mentioned it has a single solex carb. You have a what!!??!!?? Do you mean a single carb in the middle? or two single solex's one on each side? This is part of your power problems. Most carbs in the middle are a Weber or Holly and they suck. QUOTE the lines going in and out are the same size; 8mm sounds about right. nothing so substantial as 10mm. is bigger better? No, also the numbers I quoted are FI filters, they will work but a $1 bug filter will do the job. QUOTE another question: how difficult is it to do one of those "move the fuel pump to the front, away from the hot ol' engine" jobs? does it help out? Not really required, the main reason to move the pump was a battery acid/corrosion issue. |
rhodyguy |
Apr 13 2004, 06:45 AM
you can still use the stock one with carb/s. i wonder what type of fuel pump you have? if possible you need to put the filter up stream (ahead of the pump).
kevin |
ruddyboys |
Apr 13 2004, 06:50 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I would pick up one of those clear fuel filters from your FLAPS, you can see all the crap the filter stops and know when to replace it.
red914 |
Apr 13 2004, 07:23 AM
good idea, the clear filter. and the single carb in the middle is, i believe, a solex.
thanks. you all have put me on the right track. |
Mark Henry |
Apr 13 2004, 07:31 AM
QUOTE(red914 @ Apr 13 2004, 05:23 AM) the single carb in the middle is, i believe, a solex. Like I said the single carbs sucks big ones. It will work but one day you will want to put a set of dual webers on your to-do list. (IMG:style_emoticons/default/smash.gif) |
red914 |
Apr 13 2004, 07:49 AM
the duals are on the to-do list already, along with too many other things to list here. it is still fun, as it is, but i see so much unrealized potential now, having seen some other cars! (IMG:style_emoticons/default/wub.gif)
RON S. |
Apr 14 2004, 05:01 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I finally got around to capping off a digi-pic last night.
I bought a Canton Products fuel filter and as you can see,I mounted it on the firewall.There's also a clear cheapo unit up front under the tank. Ron Attached image(s) |
red914 |
Apr 14 2004, 07:37 AM
that fiilter is a mighty impressive looking piece of engineering. that position would, i suppose, keep it from overheating. for the time being, i am going to replace the current unit with something comparable: in-line, and upstream from the pump.
7391420 |
Apr 14 2004, 09:09 AM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
I thought we moved the fuel pumps to a cooler spot to prevent vapor lock? isn't that right?
also, I'm not sure about this, but I am sure that if I'm wrong someone will correct me!! but isn't the vapor lock issue primarally a FI problem and not a carb problem? if so, it doesn't matter if you move the pump because your car has a carb and so won't be affected... then again, I cant see how if would hurt to move the pump to a cooler spot... |
Qarl |
Apr 14 2004, 09:29 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
7391420,
That's the fuel FILTER, not the fuel PUMP mounted on the firewall in the picture above. |
Apr 14 2004, 10:27 AM
QUOTE(7391420 @ Apr 14 2004, 07:09 AM) but isn't the vapor lock issue primarally a FI problem and not a carb problem? Nope. It's a fuel delivery system problem. In fact, it can be worse with carbs because the higher pressures of an FI system make it harder for the fuel to boil. Plus the fact that all FI fuel systems (in stock 914s, at least) recirculate the fuel back to the (cool) tank helps keep the fuel cooler. --DD |
tat2dphreak |
Apr 14 2004, 10:29 AM
man RON, that stock prop. valve looks way out of place on that car... you need an anondized red one with Blue fittigs (IMG:style_emoticons/default/wink.gif)
j/k... very nice pic! |
RON S. |
Apr 14 2004, 01:22 PM
Yea,
It's the stock 914/6 unit.I'll probably remove it and put a Tilton adjustable unit in the car later on. I agree now after I took the pic.It does look bad. Ron |
red914 |
Apr 14 2004, 06:33 PM
hmmm, vapor lock. haven't noticed any problems like that, and i, too, was under the impression that it was a FI problem. does vapor lock prevent the engine from starting hot? or does it prevent the hot engine from revving down? (IMG:style_emoticons/default/confused24.gif)
someday, maybe, i will move the pump and filter to the front, or somewhere cool. as for now, unfortunately, cheaper is better. got a $4.50 filter, and hopefully it will keep my fuel clean as it heads into cumbustion heaven! some of you guys are mighty imtimidating with your amazing cars. i don't know that i will ever have the know-how, or the means, to do the super cool stuff you do. i could look at the pictures of modifications in these threads for hours. (IMG:style_emoticons/default/wub.gif) (heck, my wife will tell yo i already do! (IMG:style_emoticons/default/laugh.gif) ) |
campbellcj |
Apr 14 2004, 06:51 PM
Ron, I am not sure this is a real issue or just paranoia...but I would be a tad concerned about the filter and lines being wiped out by a rock or debris in the event of a track off or other misc. "incident". (IMG:style_emoticons/default/idea.gif)
(Mainly talking about the lower on on the filter can, which is down at the belly pan level of the car...would be <4" off the pavement on my car.) We have a lot of ruts, rocks, sticks, tumbleweeds, small critters, and so forth on our local tracks and canyon roads, so I am trying to route and tie everything critical down with that in mind. BTW your car looks sweet! Pretty similar to mine...except a whole lot cleaner! |
Lo-Fi Version | Time is now: 19th May 2024 - 08:53 AM |
