I think I made a mistake, suspension bushings won't bolt up? |
vintage914racer |
Aug 12 2010, 06:25 PM
Member Group: Members Posts: 429 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
So I ordered rebel racing RSR bushing for my a-arms, but now that I look at the front suspension subframe it appears that the mounts for the rear of the a-arms don't come off. The rear mounts I'm talking about are the ones labeled "RSR" in the picture. Therefore I can install the rebel mounts. Am I making sense and correct in my thinking?
914Sixer |
Aug 12 2010, 06:31 PM
They will work. All the control arms are the same.
vintage914racer |
Aug 12 2010, 06:35 PM
My main area of concern is the circled area. I don't understand how the mounts integrate on this end, there doesn't appear to be room for the rear RSR mount.
jaxdream |
Aug 13 2010, 07:30 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
You have to remove the torsion bars from the suspension , remove the adjusters and bars will come out the end after adjusters are off , then get the arms with the bushings and thier holders out of the crossmember ,pry out of that area , not real hard to remove . Then you clean up area , insert the new ones onto the arms, maybe a plastic / rawhide / rubber mallet will get them seated onto the arms. Then mount the arms with new bushings back into the crossmember .Just make sure you get the left and right sides in the correct side, these have a hole larger at top from fasctory to seat onto the mounting bracket on the body which the bigger hole slips over the bolt hole mount and the bottom with the smaller hole facing down so you slide bolts up into the mount and bolt on . Good luck , those look nice (IMG:style_emoticons/default/drooley.gif)
Jack / Jaxdream |
vintage914racer |
Aug 13 2010, 08:09 AM
The picture was just for reference, not my actual parts. I'm happy to say mine look a lot cleaner.
BigD9146gt |
Aug 13 2010, 08:24 AM
OCD member Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand |
They fit. Fallow the instructions, and ask questions here, you'll get those on. Good purchase, they work really well.
Attached thumbnail(s) |
BigD9146gt |
anotha. And yes, they work with the steel cross bar as well.
tradisrad |
Aug 13 2010, 08:36 AM
I put Elephants on my car and came across these at a later date. I really like them and there does not seem to be a need for Elephants low friction mount!
If I were to do it again I think the RSR are the way to go. You will love the ride they provide and you will quickly be looking to upgrade the rear bushings also! |
vintage914racer |
Aug 13 2010, 08:51 AM
Lo-Fi Version | Time is now: 14th May 2024 - 08:33 AM |
