2.4T engine, Change engine in a 914 |
Niklas |
Aug 13 2010, 08:23 AM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
Hello!
Is a 911 engine 2.4 T a good engine to use in a 914 ? What do I have to change to use it ? The engine is complete from the 911 with all the parts. My car is a -72 1.7. Greetings from Sweden on the lefthanders day. Niklas |
VaccaRabite |
Aug 13 2010, 08:32 AM
Hello! Is a 911 engine 2.4 T a good engine to use in a 914 ? What do I have to change to use it ? The engine is complete from the 911 with all the parts. My car is a -72 1.7. In stock form, probably not. For the possibly less money that you will spend sourcing the parts to install the 6 engine, you could build a 2056 T4 out of your existing 1.7, and that will rival the power you will get from the heavier 6. The 2.4 T only produced 130hp stock new. If it needs to be rebuilt, you are going to spend a lot of money building it. BUT, if you rebuilt the engine to E specs you will have a 165HP motor. And if you built it to S spec (and why not, if you are building it anyway) you will have a 190 hp plant. And that will be worth doing. Of course, building it to E or S spec will cost a lot, unless you can find the parts cheaper then we can here in the States. This lefty says HI on left-handers day! Zach |
Aug 13 2010, 11:15 AM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
In stock form, probably not. I dis-agree ... (IMG:style_emoticons/default/biggrin.gif) If the 2.4L is in good running condition it will certainly be more fun in a 914 than the stock 1.7L ... (IMG:style_emoticons/default/shades.gif) Andy |
proto31 |
Aug 13 2010, 11:26 AM
Member Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None |
I agree with Andy, I had an original 6 with a 2.0 and it was a blast to drive, 130 HP is nearly double what you currently have, plus the added torque. If you're looking for raw power than you need to look for a 3.2 or 3.6. Building a 2056 will cost more than rebuilding the 2.4 (assuming it even needs a rebuild) even to "E" (add $500 for E pistons and $300 for cam regrind). Just my $.02.
Dan |
brant |
Aug 13 2010, 12:13 PM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I agree with Andy, I had an original 6 with a 2.0 and it was a blast to drive, 130 HP is nearly double what you currently have, plus the added torque. If you're looking for raw power than you need to look for a 3.2 or 3.6. Building a 2056 will cost more than rebuilding the 2.4 (assuming it even needs a rebuild) even to "E" (add $500 for E pistons and $300 for cam regrind). Just my $.02. Dan Dan, I disagree on the comment about building a 2056 costing more if you take a -6 to a higher spec, you probably need to replace the cylinders too. And a set of pistons new is going to be over 1K, not 500. Plus a true E or S spec is going to need port work, heads (installing bigger valve seats is about a $1200 job and makes finding better heads the preferred choice), not to mention the case limitations of an early case (early aluminum cases are going for $2000 these days). Rebuilding more parts on a motor with more cylinders, usually costs more than a motor with less cylinders the -6 is going to cost more to rebuild in my book and I think that an important part of the answer for the original poster to know is that converting a -4 chassis to use a -6 motor is expensive. (where as the 2056 does not have the conversion costs associated with the chassis) granted the -6 will be an awesome car but it won't be "cheaper" you can factor a rebuild a 100 different ways, but here is my rough way: 914/4 starting chassis +with rebuilt 2056 + front cooler= $8K 914/4 starting chassis +rebuilt 2.4S spec motor + front cooler likely at over 150hp + full -6 conversion bits = $14K finding a used -4 motor would be apples to apples. Most people would put the cost of converting the chassis somewhere around 5K. |
Bleyseng |
Aug 13 2010, 12:24 PM
if the 2.4T runs ok, stick it in and convert it over to a six for around $5k US. Thats with no heat!
It will be about what a stock 914/6 was powerwise with the 4 gears... if you want heat and a easier install build a 2056 with carbs for 130hp..and I don't think it will cost you $5k US to do either. |
Drums66 |
Aug 13 2010, 04:06 PM
if you want heat and a easier install build a 2056 with carbs for 130hp..and I don't think it will cost you $5k US to do either. That's what I'd do but............please keep the fuel injection(2056) and I would be very content (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/stirthepot.gif) |
mskala |
Aug 13 2010, 07:08 PM
Just a few nits ...
The 2.4T made 140hp, compared to 110 for 2.0T. Also there were 2 different types, the late one had CIS (still the same power). The original poster doesn't say anything about rebuilding, and you certainly will not need a front cooler. So that removes quite a bit of expense. |
VaccaRabite |
Aug 13 2010, 07:58 PM
Given that the OP is living in Sweden, he probably has the European version of the 2,4T which only devloped 130hp. Which is why I suggested building the 2056 which can develop the same power. I built mine 2056 for about $4k USD.
Even If the 2,4 needs no work the parts for conversion could easily cost that much, and you run the risk of installing a motor that may be at the end of it's useful life instead of a fresh build. I totally agree that either motor would be a huge improvement over the 1,7 he has now. But I have been burned with old engines, so I just don't trust them. Until I have had a chance to go over them, which adds cost. What price is piece of mind? Zach |
Lo-Fi Version | Time is now: 9th May 2024 - 09:35 PM |
