Dual carb air filter housing, like the old /6 air filters |
VaccaRabite |
Aug 16 2010, 10:38 AM
En Garde! Group: Admin Posts: 13,442 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
A few years ago, I saw someone make an air filter housing for a dual carbed /4 that was similar to the old air filter housings for a /6. you know, this style:
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1281985157.1.jpg) In my continuing effort to quiet down my ride, I need to reduce the sound of my intake. Also, this would allow me to use a proper paper filter rather then the kinda craptastic K&N filters - which seem to be the only game in town if you are using dual carbs. Anyone? Zach |
Root_Werks |
Aug 16 2010, 02:39 PM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Zach, I went through all of this a while back, researched the hilt out of everything. If you want to spend the bucks, you can get that kit listed in the link above. Although it's designed for a T-4 in a T-1 body, not a 914.
If you want, I have the early 912 aircleaner housing and new elements. The pass side fits, but the drivers would need to be modified as the cyl's sit about an inch too far forward. I even have the adapter plates from solex to weber base's. Attached image(s) |
VaccaRabite |
Aug 16 2010, 08:29 PM
If you want, I have the early 912 aircleaner housing and new elements. The pass side fits, but the drivers would need to be modified as the cyl's sit about an inch too far forward. I even have the adapter plates from solex to weber base's. Maybe this is a better option. Do these flow enough air, or are they restrictive? Zach |
Lo-Fi Version | Time is now: 11th May 2024 - 03:07 AM |
