Pertronix IgnitorII on 2.0 stock FI, has anyone done it? |
steveherman |
Aug 19 2010, 04:45 PM
Member Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States |
For the ignitor 2 what modifications have to be done?
I have "HEARD" all you have to do is shave the bottom of the rotor for clearances. Does anyone know for sure if this is this true? Does anyone KNOW FOR SURE what else (if anything) has to be done? |
SLITS |
Aug 19 2010, 05:55 PM
Pull the rubber plug from the side of the dizzy to run the Ignitior wires out of. I used to pull one and drill out the copper spade terminal and run the wires through it.
All you have to do is make sure the rotor body doesn't scrape the pickup and that the height is acceptable for the cap to fit on. That's about it except for hooking the wires up and retiming the engine. |
steveherman |
Aug 19 2010, 06:47 PM
Pull the rubber plug from the side of the dizzy to run the Ignitior wires out of. I used to pull one and drill out the copper spade terminal and run the wires through it. All you have to do is make sure the rotor body doesn't scrape the pickup and that the height is acceptable for the cap to fit on. That's about it except for hooking the wires up and retiming the engine. That sounds like the install for ignitor 1 not 2 (from what i am told)... Right? I am only asking about the ignitor 2 version. |
ThinAir |
Aug 19 2010, 09:21 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
That sounds like the install for ignitor 1 not 2 (from what i am told)... Right? I am only asking about the ignitor 2 version. The last time I checked there was no version 2 for our distributors. The version 1 needed a bit of grinding to clear something (it's been so long that I don't remember what). Doing the same for an Ignitor II would be no big deal, but I could never figure out what to order since there wasn't one listed for the 914. |
SLITS |
Aug 20 2010, 07:24 AM
In looking at the images of the Ignitor II, it isn't any different than the Ignitor. Apparently, they may have added an IC chip for more features.
It's just a Hall Effect trigger. I used a Compufire module once .... all the other installations I have done were the Crane Optical XR700 (my preference). |
blitZ |
Aug 20 2010, 08:34 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I tried an Ignitor II made for a 6 cyl Bosch coil with the 4 cyl magnet piece and it never worked right. YMMV.
steveherman |
Aug 20 2010, 08:43 AM
here is the link to the 1847 series fir porsche and vw
http://www.shopatron.com/home/search/591.0...p;x=22&y=14 the one i am talking about is the 91847a |
underthetire |
Aug 20 2010, 08:47 AM
+1 on the Compu-Fire. I like it much better.
Bleyseng |
Aug 20 2010, 09:17 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
+2 on compu fire as it doesn't burn out if you leave the key on while listening to the radio....BTDT
steveherman |
Aug 20 2010, 05:38 PM
brant |
Aug 21 2010, 07:41 AM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The number you gave is for the aftermarket bosche 009, or 050 distributor.... neither of which are compatible with a stock fuel injection. That part isn't made for your car if you have stock fuel injection. I have never tried to cross models, but doubt very much it would fit.
Lo-Fi Version | Time is now: 12th June 2024 - 04:56 AM |
